Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-03-2010, 07:39 AM
DansBBF250 DansBBF250 is offline
Garage is empty, add now
DansBBF250 is starting off with a positive reputation.
1973 f250 aftermarket tires and wheels??
hello,
first i would like to introduce myselft, my Name is Dan and im a new proud owner of a 1973 ford F250 camper special. it has a Big block 390, stock carb, C6 Trans, nothing real special yet ;-)
my question is does anybody know what size rims will fit on a 1973 F250? and if i could fit a set of rims off of a newer super duty? the current wheel and tire i have is the stock 31X10.5X16.5 and the biggist issue is they stoped making tires in this size and one of my rear tires is on its last leg..
PLEASE let me know if you have any info
thanks!
  #2 (permalink)
Old 02-03-2010, 08:50 AM
nkapphahn's Avatar
nkapphahn nkapphahn is offline
nkapphahn is starting off with a positive reputation.
Hi Dan,
Your trucks bolt pattern should be 8-6.5. Superduties were switched to metric 8-170, so they will not fit. You do have the option of finding wheels off newer Dodges and Chevy's with 8 lugs 3/4 - 1 ton.
  #3 (permalink)
Old 02-03-2010, 08:55 AM
Ok, so what size rim and tire would I want from one of them??
  #4 (permalink)
Old 02-03-2010, 09:29 AM
nkapphahn's Avatar
16" would be minimum to fit over the brake calibers. I had a 71 3/4 ton that had drum brakes all around and I was able to fit 15x10 steel wheels with a -25mm offset.
As far as width, with a 10.5" wide tire you should consider going with a 8"-10" wide wheel.
  #5 (permalink)
Old 02-03-2010, 12:00 PM
Redneckryder's Avatar
Redneckryder Redneckryder is offline
Redneckryder is starting off with a positive reputation.
ok...not to hijack...but what year did the bolt pattern change?
__________________
Quote:
Originally Posted by Aussie_F_trucker View Post
REAL men have eight burnin' and four turnin'
1997 F-150 XLT 4x4 ex-cab 4.6L auto
  #6 (permalink)
Old 02-03-2010, 02:18 PM
nkapphahn's Avatar
1997 was the last year with 8-6.5.
  #7 (permalink)
Old 02-03-2010, 02:30 PM
And those are the ones that fit the dentsides....right? so 98 and up wont fit?? thanx for the info
__________________
  #8 (permalink)
Old 02-03-2010, 05:40 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
yup - 98+ won't fit without a re-drill or adapters. It's been covered over and over again. A search will bring up LOTS of threads on this...
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #9 (permalink)
Old 02-04-2010, 02:17 PM
I actually tried a search....didn't work so hot for me. I figured it had been covered...
__________________
  #10 (permalink)
Old 02-05-2010, 12:03 PM
Thumbs up
Thanks for all the great info!
Well i lucked out! About 2 days ago, I went out in search for a tire to replace the worn rear tire.. I searched and searched with very little luck, and I came across a guy giving away some tires that were sitting out in front of his yard so I knocked on his door to confirm that they where free and he said "I have a whole bunch of other tires in my back yard but you will have to dig them out of the bushes, help your self to them" so I went back there and did some serious digging, and sure enough there it was! A matching tire! It was the correct size and everything! The tread is a little different, but the tire is pretty much brand new! And I couldn't beat te price of free! :-) so, this will help me get by untill I can buy some 16" rims and tires!
  #11 (permalink)
Old 02-05-2010, 03:16 PM
Damstr8's Avatar
Damstr8 Damstr8 is offline
Damstr8 is starting off with a positive reputation.
A very smart man said this once in a tread about 15" rims on a F250.
Quote:
Originally Posted by 75F350 View Post
Its all about the backspacing. You will require a set of wheels with 3 3/8" backspacing or less. Many companies offer 3" as well as 2.75" backspacing.
Failure to find the right wheel with the correct backspacing will result in clearance issues.
Here is a 42" tire on an 8 lug 15" wheel:
Click the image to open in full size.
Its the right way to do this. You do not want to waste money on spacers. This can be a problem, and after the cost of the spacers are realized, you will have more than the total cost of the correct wheel.
*Note* this is for steel wheels. Aluminum wheels are to thick at the bead for this measurement, and will require more backspacing which is not all that common, and may be too much for the bearings.
  #12 (permalink)
Old 02-05-2010, 04:26 PM
fellro86's Avatar
fellro86 fellro86 is online now
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Most 8bolt wheels up to the mentioned 97 trucks will fit. GM used a smaller center hole, but all the aftermarket wheels were the same. 88 and Newer chev's have a negative offset factory. Dodge wheels are a straight trade, not sure when they changed their pattern, if they have.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
Tags
1970, 1972, 1973, 19731979, 31x105x165, axle, f250, fit, ford, manual, online, pickup, rear, rims, size, stock, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
