Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-02-2010, 11:01 PM
Genesis Genesis is offline
Garage is empty, add now
Genesis is starting off with a positive reputation.
E-85
Bear with me if this is a stupid question. I own a 2010 Ford Escape with the V-6 Flex Fuel engine. It's designed to be run on E-85 if so desired. A couple of local stations are finally selling the E-85 by me. If I choose to use the E-85 does it matter how much regular gas is in the tank already. It's extremely unlikely I would be able to run the E-85 consistently due to availability issues, so I'm just curious what the results would be. Thanks in advance.
__________________
2003 E-350SD, V-10, 373LS, 4R100, 3" rear lift, Diablo Tune
  #2 (permalink)
Old 02-03-2010, 10:24 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Self adjusting for any mix from straight gasoline to E-85. Your results will be less mpg's.
Jim
  #3 (permalink)
Old 02-04-2010, 02:41 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
I have an 05 Sport Trac Flex Fuel and I ran E85 when fuel prices got up to $4
I lost about 3 mpg. I do not run it now unless there is at least 50 cents per gallon difference.
Performance wise I could not tell much difference
regards
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
