Carb for 66 F-100
Carb for 66 F-100
Many thanks to all the folks who chimed in to help with my starting problem, and rolling problem. This is a really great group of guys and I hope to be able to contribute, not just learn.
I got the truck to fire up and idle, but it understandably sounds rough. I have purchased and plan to install plugs wires, points, cap, rotor and brake lines, but as I looked under the hood while the engine was running, there was a stream of gas pouring from two or three places on the carb.
I took it to a local (sacramento) carb guy and he recommended getting the stock carb, a model 2100 clock face 114. If I find a core he can rebuild it.
Any thoughts on how I can obtain one? I did a cursory look thru google and wasted about an hour getting nowhere...
Thanks again for everyone's help in getting the old baby running...
well i have a stock autolite carb off of my 66 352 u can have but lots of luck geting it to accelerate correctl at low rpm without backfiring. i think its jetted too lean but as u can see i gave up on it in favor of a 4 barrell holley and intake. not sure id try it but your welcome to if u want it!
Does it mean that current (leaking) carb is not a stock carb? There are lots of Ford 2100s on EBay for widely varying prices. You could buy one of those either already rebuilt, or rebuild it yourself. BUT before I did that, you should probably check with Numberdummy if you care about the exact application.
I was rebuilding one this week and was surprised to learn it was a 4WD specific carb. , so it had a different float bowl and a few additional components. I never figured they had such a thing in 66'. Good luck.
