1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
no power
Old 02-08-2010, 12:54 PM
countryboy711's Avatar
countryboy711
countryboy711 is offline
no power
went to start my 2004 f250 and nothing happend. new battery put in and still nothing. i have power goin to the altnater and the starter and the fan but nothing goin into the fuse box. i unpluged the computer and poked the tester into the ports and coulndt find power. any ideas would greatly help.
Old 02-08-2010, 02:36 PM
Y2K1TON's Avatar
Y2K1TON
Y2K1TON is offline
Did you check any under hood fuses and relays? If you have at least a chilton manual it will have the wiring diagram in it. You should have constant 12V going into the ignition switch under the dash but I'm not sure if it goes through the fuse block first. It probably does.
Good luck
