f150 on 44's - Ford Truck Enthusiasts Forums
f150 on 44's
Old 02-02-2010, 07:27 PM
cjncrckhead17 cjncrckhead17 is offline
cjncrckhead17 is starting off with a positive reputation.
f150 on 44's
i want to lift my 2001 ford f150 and put dana 60's underneith it and lift it and put 44's on it any one done it
i need to know lift hight
engine mods
and gear mods
Old 02-02-2010, 07:31 PM
73'360f100's Avatar
73'360f100 73'360f100 is offline
73'360f100 is starting off with a positive reputation.
You might want to rethink that rear dana60. Its not much better than a 9 inch you might want to go to a sterling 10.25
Old 02-02-2010, 08:11 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
Quote:
?????????? Dana 60's are tons better than a 9"
Old 02-02-2010, 09:16 PM
73'360f100's Avatar
The front D60's are but the rears are not that much better but they are better. If you are already doing it custom you might as well go with the sterling.
Old 02-02-2010, 09:22 PM
nflfreak43's Avatar
i still disagree but i understand your thought. but if your goin custom he should go Rockwell 2.5 tons. lol.
Old 02-02-2010, 10:03 PM
so will the dana 60's hold up to the 44's cause ive already got them and i would rather not send just the rear back and any ideas on what gears i should run ?????
Old 02-02-2010, 10:35 PM
nflfreak43's Avatar
yeah they will hold up just fine.
Old 02-02-2010, 11:44 PM
73'360f100's Avatar
Quote:
But then again if your doing that why not just go 5 tons and 54's. Why stop at 44's lol. If you already have them then yes run them I was just speaking as if you hadn't bought axles yet. They will hold but the sterling would have just been piece of mind. For a cruising rpm (65 mph) of 2626 (better gas mileage) use a 5.29 for a cruise rpm of 3559 (more power) use a 7.17or somewhere in between for a compromise. I found this info at 4Lo.com :: Gear Ratio & Tire Size Chart
Old 02-03-2010, 09:14 AM
i thought about going 54's but then i have to get into legal hight and a buddy of mine already has 54's on his f250 outlaw and has more trouble with it than anything plus i have seen a 2000 + f150 running around on 44's the biggest i seen is 38's another thing what kind of engine mods will i have to make to my 5.4 if i put 7.17 gears in it and thanks for the chart look up
Old 02-03-2010, 09:35 AM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
Those guys are right on the rear D60 is not being a great choice. The stock axle shafts are the weak point on these rear ends. A buddy of mine was snapping them like toothpicks in his Dodge with 40s on it, we ended up yanking it a stuffing a D70HD out of a motorhome under it. I believe Moser is who offers some monster 35 spline shafts to replace the dinky stock 30 spline pieces. However if you do this you will have to have the spindles hogged out to accommodate the bigger shafts. By the time you are done spending all that money you will still have to figure out how to install the VSS (vehicle speed sensor) and the exciter ring on this axle. You'll need the VSS in order to keep the computer happy. It would be easier and cheaper to go with an 87 and newer 10.25" Sterling, it's all ready set up for the VSS... plus they are much stronger than a D60 rear. The D60 front will handle 44s no problem, for gearing I would recommend either 5.13s or 5.38s. A stock motor will turn big tires no problem if the gearing is properly matched to the tire size.
Old 02-03-2010, 06:37 PM
Cnorth6525 Cnorth6525 is offline
Cnorth6525 is starting off with a positive reputation.
I got a friend that had a 99 f150 w/ solid axle conversion. He took his truck to Full Throttle Suspensions and had 19" of suspension.
Old 02-03-2010, 11:52 PM
Pkupman82's Avatar
Quote:
What type of suspension did he go with? Leaf sprung, coils, coilovers...? Just curious. I haven't seen any 97 and newer F150s with SAS where I live, of course most people where I live are Chevy guys
Old 02-04-2010, 09:26 AM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
Quote:
do a sas search on here. this has been brought up e few different times. there are a couple threads on it and some good pics.
Old 02-04-2010, 02:39 PM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
98 f-150 dana 60's 16" of lift and 44" boggers
Old 02-04-2010, 02:48 PM
post pics of your lifted 78 or 79 f150s 1979fordf150rebel 1973 - 1979 F-100 & Larger F-Series Trucks 46 04-16-2013 04:02 PM
99 f-150 mods waterfowl14 1997 - 2003 F150 6 02-22-2012 08:36 PM
1978 f150 lift kits Dark Racer 212 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-06-2012 09:03 PM
Looking to lift 88 f250 How much lift to clear 44s fordBigBlock Brakes, Steering, Suspension, Tires, & Wheels 1 12-17-2011 02:41 PM
What tie rods for SAS d44 cyclospot Offroad & 4x4 20 01-09-2010 09:45 PM
Tags
1984, 44s, axle, biggest, convertion, f150, fabtech, ford, front, motor, possibly, put, solid, spindles, track, trucks, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
