97 f150 4.6 engine spec's??? - Ford Truck Enthusiasts Forums
Old 02-02-2010, 12:41 PM
z 97ford1 z 97ford1 is offline
z 97ford1 is starting off with a positive reputation.
Where on the internet can one find ACCURATE ford engine spec's for the 97 f150 windsor?
My oem manual can be confusing.
Old 02-03-2010, 11:51 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Exactly what specs are you looking for?
Old 02-04-2010, 07:29 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Old 02-04-2010, 10:01 AM
Moto Mel's Avatar
I have only just looked at the site listed above and will read it later. I does have a lot of useful inormation from what i have seen so far.
Old 02-04-2010, 11:53 AM
Well, I bought the book....rebuilding the 4.6/5.4 engine by georg reid but their subject engine is using oversized components and it refers a lot to those parts, not standard size engine components.
My ford oem manual is full of errors and is a bit confusing, (i'm not a engine builder).
I'm just trying to gather the most complete and accurate info I can get.
I'm sure I could use my manual and get it done but a second and maybe third opinion is better.
Torque, cylinder wall to piston clearance, cylinder taper etc.
Old 02-04-2010, 11:08 PM
Moto Mel's Avatar
I posted some information earlier and it doesn't show so I'll try again.
I looked through my service manual and cannot find engine clearance spec.s for the later engines. I'm quite sure I have them in my Mark VIII manual and although they are for a 4.6 DOHC they should apply to your engine.
It seems that Ford either doesn't trust their techs to rebuild one of these engines or they do not want anyone else to be able to, such as rebuilding shops that compete with them in the sale of Reman engines, short blocks and cylinder heads.
In any case here are the torque specs, again.
SPECIFICATIONS
Torque Specifications Description Nm Lb/Ft Lb/In
Belt Drive Tensioner 20-30 14.7-22 —
Belt Idler Pulley 20-30 14.7-22 —
Brake Booster Hose 8.9-12.1 — 79.4-108
Camshaft Bearing Cap Bolts (1) (1) (1)
Camshaft Cover Bolts (1) (1) (1)
Camshaft Position Sensor (CMP) 8-12 — 71-107
Connecting Rod Bolts (1) (1) (1)
Crankshaft Main Bearing Bolts (1) (1) (1)
Crankshaft Main Bearing Side Bolts (1) (1) (1)
Crankshaft Position Sensor (CKP) 8-12 — 71-107
Crankshaft Pulley (1) (1) (1)
Cylinder Heads (1) (1) (1)
Engine Front Cover Bolts (1) (1) (1)
Engine Mount to Block Bolts 53-72 38.9-53 —
Engine Mount Pivot Bolt 68-92 49.9-67.6 —
EGR Tube Fittings 35-45 25.7-33 —
Exhaust Manifold to Cylinder Head Nuts (1) (1) (1)
Exhaust Manifold to Three Way Converter Nuts 34-46 25-34 —
Flywheel Bolts (Automatic) (1) (1) (1)
Ignition Coil Bracket Bolts 20-30 14.7-22 —
Ignition Coil Bracket Nuts 20-30 14.7-22 —
Inner Fender Splash Shield 10.2-
13.8 — 91-123
Intake Manifold (1) (1) (1)
Intake Manifold Tuning Valve 9-12 — 80-107
Knock Sensor (KS) 20-25 14.7-18 —
Oil Pan Drain Plug 11-16 — 98-143
Oil Filter 14-17 10-12.5 —
Oil Filter Adapter 20-30 14.7-22 —
Oil Pan (1) (1) (1)
Oil Pressure Switch 12-16 — 107-143
Oil Indicator Tube 8-12 — 71-107
Oil Pump 8-12 — 77-107
Oil Pump Screen and Cover Bolt 8-12 — 71-107
Oil Pump Screen and Cover Spacer 20-30 14.7-22 —
Oil Pump Screen and Cover Spacer Bolt 20-30 14.7-22 —
Rear Oil Seal Retainer Bolt 8-12 — 71-107
Spark Plugs 9-20 — 80.3-178
Timing Chain Guide Bolts 8-12 — 71-107
Timing Chain Tensioner Bolts 20-30 14.7-22 —
Transmission Fluid Fill Tube Bolt 18-23 13.5-16.5 —
Water Pump Bolts 20-30 14.7-22 —
Water Pump Pulley Bolts 20-30 14.7-22 —
Water Temperature Indicator Sending Unit 16-24 11.7-17.6 —
Engine Coolant Temperature Sensor (ECT) 16-24 11.7-17.6 —
Generator Battery Positive Lead 7-9 — 62.5-80.3
Generator to Block Bolts 20-30 14.7-22 —
Generator Bracket Bolts 8-12 — 71-107
Heater Return Tube Bolts 40-55 29.4-40.4 —
Power Steering Bracket Bolts 8-12 — 71-107
Power Steering to Block Bracket Bolts 35-45 25.7-33 —
(1) Refer to this section for tightening procedure and sequence.
Old 02-04-2010, 11:16 PM
Moto Mel's Avatar
SPECIFICATIONS
Brake Booster Hose 8.9-12.1 79.4-108
Camshaft Position Sensor (CMP) 8-12 71-107
Crankshaft Position Sensor (CKP) 8-12 71-107
13.8 91-123
Intake Manifold Tuning Valve 9-12 80-107
Oil Pan Drain Plug 11-16 98-143
Oil Pan (1) (1) (1)
Oil Pressure Switch 12-16 107-143
Oil Indicator Tube 8-12 71-107
Oil Pump 8-12 77-107
Oil Pump Screen and Cover Bolt 8-12 71-107
Rear Oil Seal Retainer Bolt 8-12 71-107
Spark Plugs 9-20 80.3-178
Timing Chain Guide Bolts 8-12 71-107
Generator Battery Positive Lead 7-9 62.5-80.3
Generator Bracket Bolts 8-12 71-107
Power Steering Bracket Bolts 8-12 71-107
Old 02-06-2010, 01:01 PM
Thanks moto mel.
Actually, my 97 oem manual has these and the machining spec's.....it's just that I don't trust all of it since there are errors thru and thur.
Like, what's the correct cylinder wall taper for these 4.6's?
Using the standard oem "hypereutectic pistons" that these engines came with.
The reason I'm harping on this is because I may attempt to rebuild mine or maybe find another one I can work on while watching my engine rack up the miles.
All of the used engines I go and look at have some serious vibrations on the motor......I can actually see the engines move side to side a good 3/8".
I go home and look at mine and at 340k miles it runs so smooth I can't even tell it's running.
Old 02-06-2010, 04:00 PM
Moto Mel's Avatar
Quote:
Originally Posted by z 97ford1 View Post
Thanks moto mel.
My hard copy '98 Lincoln DOHC manual has the specs but you do have to be very careful when using any manual or any source other than the engineering data sheets. Bore taper is a critical dimension and with the hypereutectic pistons you have to be at .0002 taper or less as the piston to wall clearance is very tight. Forged pistons require more clearance due to the rate of expansion but taper is still very important. I suggest that you have the cylinders done by a shop that has a very good reputation and late model machinery. A Sunnen Hone is the best for top quality bores, depending on the machinest of course. You could have them show you the taper with their bore guage both before they do the job and again after. This would prove bore size and taper. They should not be unwilling to do this for a customer.
97 ford f150 4.6 swap kdagenais 1997 - 2003 F150 6 01-08-2017 10:00 AM
Changing specs on a ecm Kevin Kavon Performance & General Engine Building 4 12-15-2015 06:25 PM
F150 4.2 ENGINE SPECS ford 4.9 300 3.8 & 4.2L V6 2 01-24-2015 01:24 PM
'97-'98 vs. '99-'01 5.4L engines RobbyMartin 1997 - 2003 F150 21 01-13-2013 09:43 PM
'97 F53 torque specs ms_johnson 1987 - 1996 F150 & Larger F-Series Trucks 3 04-25-2011 10:03 AM
Tags
1997, 46, 54l, 97, engine, engines, f150, ford, intake, manifold, motor, mount, rebuild, spec, specs, torque, tuning, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
