front spring removal - Ford Truck Enthusiasts Forums
Old 02-02-2010, 12:54 AM
bigmacmonday's Avatar
bigmacmonday bigmacmonday is offline
bigmacmonday is starting off with a positive reputation.
How do you remove the front coil springs on the 87-96 f-series?
Old 02-02-2010, 12:59 AM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
get some spring compressors and tighten them down to hold the spring copressed a little then take the retaining bolt off the bottom.... i think thats all.......
but do use spring compressors and jackstands ... so u dont launch the spring threw ur neighbors front door and knoch the truck off on ur self or somebody
Old 02-02-2010, 01:33 AM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
There is also a clip with a bolt at the top/side of the spring that you have to remove
Old 02-02-2010, 04:10 AM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
Bigmac,you gotta get you a repair manual!
1. Remove upper spring retaining bolt.
2. Place floor jack under the spring
3. Remove shock
4. Lower jack slowly
5.Presto!
Old 02-02-2010, 06:18 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
You should not need a spring compressor. I didn't. I didn't even need one for the leveling springs I used to have.
Use a floor jack under the I beam and radius arm. Jack it up and put a jackstand under the frame. Then after the lower shock bolt is removed and the spring retainers top and bottom are removed, the suspension should drop down far enough for the spring to fall out. I think with the leveling coils I had to push down on the suspension a little.
What are you replacing your springs with, new ones or taller ones?
I think the lower spring retaining nut is 1 1/8 inch.
Old 02-02-2010, 11:07 AM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
My experience was just like Texasguy's. Once the retaining bolts were out, I had to step on the hub to push it down far enough for the spring to fall out but its pretty simple.
Old 02-02-2010, 11:19 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
Why do you give people advice on things you've never done yourself?
You don't need a spring compressor. Just jack the truck up and let the axle hang. There is a small clip that retains the top of the spring. There is also a large retaining nut at the bottom. Drop the socket (I think it's 1 1/8") through the hole in the top of the coil bucket and take the bottom nut out. Use lots of PB if it's rusty.
Old 02-02-2010, 11:54 AM
Hitokori's Avatar
the manual says use a chain but compressors are easier to come by there is a safe way and a way that could launch the spring out and possibly kill somebody...
advice on things ive never done myself exactly what all have u done keep ur rude *** comments to urself
Old 02-02-2010, 12:05 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Wow you don't need a spring compresser to get them out , there not going to jump out & kill nobody , buy the time you lower the jack theres hardly any pressure on them u just pull them out ..At most you just use a pry bar ...Lew
Old 02-02-2010, 12:10 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
You can't get your post count up as fast that way!!!
Old 02-02-2010, 12:11 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Getting a wrench on the retainer nut is a task all in itself. I bought a 1-1/8 boxend wrench from a local bulk tools house and cut the open end off it with a hacksaw. That allows you to slide on the 5 foot long piece of pipe you will need to produce sufficient torque to break the nut loose, and it easily fits in between the spring coils. You will need a massive impact wrench to produce the same TQ and just getting at the nut with a socket is a chore.
Old 02-02-2010, 12:15 PM
andym's Avatar
You don't need a spring compressor. There is no danger if you remove all the tension from the spring by letting the axle hang. If you had ever done this job before you would know that. Do you always raise the vehicle, secure it with jackstands and disconnect the battery before performing any repair like the book says?
I wasn't being rude. You'll know it when I am.
Old 02-02-2010, 12:19 PM
Josh2021's Avatar
Josh2021 Josh2021 is offline
Josh2021 is starting off with a positive reputation.
The bottom retaining nut is a 1 1/8" and you will not need a spring compressor. Once the truck is jacked up there is no pressure on the spring especially with the axle hanging/sagging down. Once you remove the top retaining clip and bottom spring perch nut, you may have to push down on the axle to get the spring out but I didn't need to push down on my to get my springs out as they pretty much just fell out.
Old 02-02-2010, 12:24 PM
Thanks everyone for the info! I am heading to a pick n pull here in a few that says they have some f250's and 350's. i am going to get the front springs off of one of them to level my f150 out . That is why i needed to know how to remove them easily since ill be doing it in the junk yard.
Old 02-02-2010, 01:09 PM
andym's Avatar
Quote:
How do you plan on getting it aligned? Are you going to get the correct camber bushings to correct the alignment? Are you going to install them yourself or have a shop do it? Have you found a shop that knows how to install the correct bushings and align it?
You should have good answers to all of these questions before you start working on this project.
Front springs green_95 1994.5 - 1997 7.3L Power Stroke Diesel 4 05-18-2016 06:01 AM
1954 front coil springs Wildebird 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-16-2014 07:41 PM
Front spring bushings stlouis55 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-21-2014 06:42 AM
Front Spring Removal 73FOMO 1987 - 1996 F150 & Larger F-Series Trucks 15 06-23-2011 09:38 PM
Strut/spring removal?? ALJR 2004 - 2008 F150 3 04-10-2009 10:56 AM
Tags
150, 1988, 1995, 1996, bolt, change, changing, coil, f150, front, nut, retainer, spring, springs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
