Water in heat/ac vents after rain - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-01-2010, 02:38 PM
Daryl Hunter's Avatar
Daryl Hunter Daryl Hunter is offline
Daryl Hunter is gaining momentum as a positive member of FTE.
Don't get much rain here in SoCal except during the winter.
After the last rain I noticed that there was water in the heating/ac vent system - or at least that's where I think it was.
When I made a right hand turn some water slopped out onto my foot and gave me quite a shock for a second till I figured out what had happened.
I suspect that there must be some kind of drain tube for the vent system that's become clogged, but before I start crawling around under the truck and dash I figured I would ask here first.
Anyone seen this before and have a helpful tip on clearing the clog?
Thanks
Old 02-01-2010, 03:07 PM
Futuresweets-10's Avatar
Futuresweets-10 Futuresweets-10 is offline
Futuresweets-10 is gaining momentum as a positive member of FTE.
Very odd.... I cant be of much help, but in the 3 years ive owned my truck ive had water in my overhead console/display three times... Kinda hit or miss...
Old 02-01-2010, 09:55 PM
Thanks, for the reply.
I don't have any water leaks through the windows, headliner, or sun roof. Have not run it through a car wash since the rains, but whenever I did, no leaks were noticed.
Old 02-02-2010, 12:04 AM
JKBrad's Avatar
JKBrad JKBrad is online now
JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.
More than likely the windshield adhesive is breaking down and causing the leak. Time for a new windshield with new adhesive. You might be able to find a glass shop that will be ables to seal it up without replacing it. After 7 years it should be pitted up enough to justify a new one though.
Old 02-03-2010, 11:48 AM
Quote:
If a glass shop can re-seal it with out new adhesive they are breaking the law. If they try to re-use the same windshield they are also likely breaking the law. Laws vary from state to state, but in most both are illegal. The windshield is a vital part of roll over protection and protection for the driver from objects thrown from the road. Re-sealing a windshield that has adhesive broken down does not solve the real problem. The adhesive would never break down if it was installed properly... If it is the windshiled have a qualified glass technician put a NEW WINDSHIELD in. If they tell you they can reseal it or pull it out and re-install it, I wouldn't consider them qualified.
Old 02-03-2010, 12:40 PM
JKBrad's Avatar
Quote:
Good point about the integrity and legality. Didn't know that.
In the Southwest it's not uncommon for winshield adhesive to break down after 8-10 years or so, especially on a vehicle kept outside. Clean water leaking from under the dash is usually what indicates the problem.
Old 02-03-2010, 01:30 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
If it is warm enough to be using the air conditioning there, after it has been on a little while, check under the passenger side (and a little forward) to see if you can see a little drip of water (smell it) to make sure the drain is open. No water coming out, it's probably clogged and you'll have to get that tube cleaned out.....Other than locating the other end and blowing thru it, I don't know how that might be done.... someone should be by here soon that it may have happened to and can tell you what he did!
Old 02-03-2010, 02:43 PM
Thanks guys,
I'm about 99.9% sure that it's not the windshield leaking.
Will try to get some quality time with it this weekend and investigate further.
Daryl
Old 12-22-2013, 05:25 PM
lgh1157 lgh1157 is offline
lgh1157 is starting off with a positive reputation.
Daryl did you ever solve this issue ?
This just happened to me this afternoon
Thanks !
L
Old 12-22-2013, 05:53 PM
I went through and made sure all vents were not clogged and it hasn't happened since.
Not sure exactly what fixed it though.
Water leak causing power liftgate to open itself and set off alarm Stevem8 2007 - 2014 Expedition & Navigator 12 02-10-2017 08:07 AM
Leak in Cab of Truck. ajbrown208 1999 - 2003 7.3L Power Stroke Diesel 4 03-29-2016 12:07 PM
AC condensation cdorr0 2009 - 2014 F150 10 07-29-2015 07:35 PM
bed drain holes - why not? speakerfritz 1999 to 2016 Super Duty 11 04-01-2014 02:56 PM
water blowing on floor when blower is on after alot of rain phillycincykid Cooling, Heating, Ventilation & A/C 2 07-14-2013 09:57 AM
Tags
2003, ac, air, breaking, clogged, conditioning, edge, ford, glue, leaking, rain, system, truck, vent, vents, water, windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
