Spindle Removal Dana 60
I'm trying to install gears into my dana 60, but I can't get the spindles off. I have taken many d44 spindles off in the past, but none were as stubborn as these 60 spindles. I have ruled out the hammer and chisel method, and the rubber mallet method. I have heard of building a rig that bolts to a slide hammer and screws onto the spindle threads. So my questions are:
1. What methods have ya'll used to remove stubborn spindles?
2. Does anyone know the part number for spindle nuts?
Passenger Spindle which has not been messed with.
Drivers Side which I have pounded on.
take a block of wood and put it down on the end of the spindle (over the threads) and hit it with a bfh. Then work around in 90* incriments. It might take several times because it looks like the disk brake backing plates have completely rusted out.
Rich at Welcome to Complete Off Road can help you with your spindle nuts if your local autoparts store cannot.
at this point I dont think a slide hammer deal will help you. Maybe you can build something on the order of this SPINDLE PULLER TOOL DANA 30,44 MORE or its time to get a bigger F H.
I know they are PITA. My D60F came from Ohio and was quite rusty.
on
soak every inch of that seam and backside of the thing with pb blaster and come back tomorrow. If you have already tried this then heat it up real hot, not quite red, but hot, with a torch and dump cold water on it immediately. I know it sounds craZY but I have seen a few welding and machine shops do it and it cools fast enough to shatter the rust. some times it takes a few trys but I would try the blaster oil first. Another idea is water. Believe it or not, water can loosen rust. It creates it and it can loosen it too.
thekingofcows
24
03-29-2012 09:53 PM
