what is a COP???? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what is a COP????
Old 02-01-2010, 09:21 AM
Jbrown8988's Avatar
Jbrown8988 Jbrown8988 is offline
Jbrown8988 is starting off with a positive reputation.
what is a COP????
truck is skipping...not at idle but when driving.....sometimes at idle it will bog down but then catch up again... i did a search and can't figure out what a cop is??
Old 02-01-2010, 09:33 AM
Danno77 Danno77 is offline
Danno77 is starting off with a positive reputation.
Coil On Plug or Coil Over Plug?
Old 02-01-2010, 09:39 AM
bbender85's Avatar
bbender85 bbender85 is online now
bbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud of
coil on plug. instead of having a couple coil packs with spark plug wires or a distrubutor and plug wires, there is a coilpack mounted right on each spark plug.
Old 02-01-2010, 09:46 AM
1buzzbait's Avatar
1buzzbait 1buzzbait is offline
1buzzbait is gaining momentum as a positive member of FTE.
yer kiddin me right?? coil on plug?? ddaayyuumm--i aways thought it was dem boyz in blue always chasin after me!!!
Old 02-01-2010, 09:50 AM
Jbrown8988's Avatar
oh ok what a dumb azzz i am!
yea i dont think its a coil....
dealer said look for a vacuum leak, so we are doing that now! I wish all it was was a coil! usually thats what is wrong but it is just acting different this time.
Old 02-01-2010, 09:52 AM
you SHOULD throw a code if it's misfiring due to coil problems. have you read to see if anything is "Pending"????
Old 02-01-2010, 10:10 AM
Jbrown8988's Avatar
no codes..... the pcv valve hose is sucking tight. We just put a new pcv valve in and still sucking the hose
Old 02-01-2010, 10:50 AM
1buzzbait's Avatar
Quote:
--no i didnt mean nuthin by that--i was bein a smart-azz--ya know cops--etc.--sounds to me like sumpthin is clogged to cause the pcv line to collapse!
Old 02-01-2010, 01:03 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Quote:
You will not get a CEL or any Code for a misfiring coil unless there is a complete failure of the coil. SD's are over 8500 GVWR and or not required to follow ODB II complience. See the link below.
http://www.ford-trucks.com/forums/51...t-come-on.html
If there is a misfire in a coil it will be stored as a Pending Code if there has been enough misfires. Most scanners can read the Pending Codes but it's a seperate menu from normal Codes.
Old 02-01-2010, 01:09 PM
Thanks for that info. I didn't know any of that, thanks for the link.
Old 02-01-2010, 01:18 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
COPs are those pesky little things with lights on the cars that never seem to leave me alone! lol
Seriously, the guys are right, it is Coil On Plug. It replaced the twin coil packs found on earlier model modular engines. Ford swapped out the packs to the COPs in 1999 on the Mustang, not 100% on the trucks. By the way, if the pack is going out, you might want to take a look at the boot. They are prone to failure causing the pack not to work properly. What may cost you $45 may actually be a replaceable $10 boot.
Old 02-01-2010, 05:03 PM
Monster-4's Avatar
No problem. When I first got this truck it took be a bit to wrap my head around the idea it was basically and ODB-I system with an OBD-II interface.
Old 02-01-2010, 07:40 PM
yeah, I'm looking hard at a 1999 F350. this will be a hard one for me to get used to if i get that truck....
Old 02-01-2010, 08:20 PM
johnnysF350's Avatar
johnnysF350 johnnysF350 is offline
johnnysF350 is starting off with a positive reputation.
Replace the pcv hose if it is sucking tight... They get soft with age, a good pcv hose is pretty firm and shouldn't suck closed.
Old 02-05-2010, 06:59 PM
slucas14 slucas14 is offline
slucas14 is starting off with a positive reputation.
Speaking of cop, the same one keeps cracking in my truck, 2001 350 v10, cylinder #10. Sometimes it will last a few months down to a day or 2, Am I putting it in wrong or doI have problems?
Thanks
can I mix COP types blackestate Expedition & Navigator 4 08-03-2013 12:31 AM
Interesting (to me) COP Discovery JWA 1968-2013 Full Size Vans 3 07-25-2013 07:10 AM
Aftermarket COP Question Rudeman Modular V8 (4.6L, 5.4L) 23 08-11-2011 01:24 PM
still sputtering and missing??? sandaholics Modular V10 (6.8l) 13 01-30-2011 10:01 AM
Testing COPS jjpic Expedition & Navigator 4 10-07-2008 10:29 AM
Tags
03, 2005, bad, coil, cop, cops, duralast, escape, ford, masterpro, motorcraft, navigator, part, reliable, si, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
