VACUUM PUMP
VACUUM PUMP
I've got a 2001 E-350 w/7.3. Does anyone know how much vacuum the pump puts out. The reason I'm asking is the brakes are hard to stop the vehicle. I replaced the booster and that helped with the hardness of the pedal but it didn't take care of the stopping. I still have to stand really hard on the pedal to get it to stop.
on
I tried to find the vacuum specs on my Ford dvd manual, but I didn't. It's been quite a while since I worked on a 7.3 with the mechanical vacuum pump. I want to say less than 15 inches of vacuum will give you hard pedal problems. Have you installed a vacuum gauge to the pump and checked it yet? You could attach a hose to the pump's connection and draw on it to see if the diaphragm is ruptured. Are the HVAC vents functioning normally?
Yeah it's been awhile since I've had to work on one of these as well. I do know that the vacuum I'm putting out definately isn't enough to get everything working the way it should as I only have 5 lbs. vacuum. But I do know that when I replaced the brake booster the pedal became softer. That is the reason for my question.
on
Cool! It's been over 10 yrs since I replaced one and I didn't bother to check the vacuum reading then. It will be some good info for the memory banks. We have a few vans, that we contract on, at our company. I can pass on the info to the mobile mechanics who work on them. I work on them, occasionally, when they come into our shop for service.
