VACUUM PUMP - Ford Truck Enthusiasts Forums
VACUUM PUMP
Old 02-01-2010, 08:53 AM
renchr56 renchr56 is offline
renchr56 is starting off with a positive reputation.
VACUUM PUMP
I've got a 2001 E-350 w/7.3. Does anyone know how much vacuum the pump puts out. The reason I'm asking is the brakes are hard to stop the vehicle. I replaced the booster and that helped with the hardness of the pedal but it didn't take care of the stopping. I still have to stand really hard on the pedal to get it to stop.
Old 02-01-2010, 09:14 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Our trucks don't use vacuum to boost the brakes, it gets its boost from the powersteering pump. Be sure to use ATF in the powersteering pump, not powersteering fluid.
Old 02-01-2010, 09:19 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
I tried to find the vacuum specs on my Ford dvd manual, but I didn't. It's been quite a while since I worked on a 7.3 with the mechanical vacuum pump. I want to say less than 15 inches of vacuum will give you hard pedal problems. Have you installed a vacuum gauge to the pump and checked it yet? You could attach a hose to the pump's connection and draw on it to see if the diaphragm is ruptured. Are the HVAC vents functioning normally?
Old 02-01-2010, 09:22 AM
Quote:
Roland, how does vacuum effect the brake pedal?
Old 02-01-2010, 09:24 AM
mueckster's Avatar
Rick,
He has an E-series van. Different animal. They have the vacuum assist brakes on the E-150 thru 350. E-450 has hydroboost.
Old 02-01-2010, 09:28 AM
Rick,
lol, OK. I was wondering what the heck was going on. Didn't dought you, just wondering what I was missing.
Old 02-01-2010, 10:07 AM
Yeah it's been awhile since I've had to work on one of these as well. I do know that the vacuum I'm putting out definately isn't enough to get everything working the way it should as I only have 5 lbs. vacuum. But I do know that when I replaced the brake booster the pedal became softer. That is the reason for my question.
Old 02-01-2010, 10:25 AM
mueckster's Avatar
Sounds like the vacuum pump is next on the list.
Old 02-01-2010, 10:29 AM
Yup sure does. It's gotta be that as everything else is working. When I get it swapped out will let you all know what the vacuum is
Old 02-01-2010, 10:36 AM
mueckster's Avatar
Cool! It's been over 10 yrs since I replaced one and I didn't bother to check the vacuum reading then. It will be some good info for the memory banks. We have a few vans, that we contract on, at our company. I can pass on the info to the mobile mechanics who work on them. I work on them, occasionally, when they come into our shop for service.
Old 02-01-2010, 02:32 PM
Well the answer to my question is... New vacuum pump will put out between 25 - 27 in. vacuum. It was definately the vacuum pump. Thanks everyone
Old 02-01-2010, 10:49 PM
mueckster's Avatar
Glad to hear that fixed your problem.
Old 02-07-2010, 02:21 PM
Dieselthree Dieselthree is offline
Dieselthree is starting off with a positive reputation.
Vacuum Pump failure
I have 2001 7.3 liter turbo diesel E-350. I have replaced the vacuum pump 4 times over the last four years. What causes the pump to fail?
Old 02-07-2010, 02:27 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
What did fail?
Old 02-07-2010, 02:39 PM
pump starts to make a lot of noise. Lose pressure on brake pedal. The first press on the pedal has some pressure. The second has almost none. I have had it replaced at two different dealers hips and two different independent shops.
1997 F250 Hard pedal, no brakes, intermittent grizzley30814 Brakes, Steering, Suspension, Tires, & Wheels 4 01-23-2017 07:15 PM
Vacuum pump problem? kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-23-2016 06:44 AM
vacuum pump or booster??? regidog Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 03-01-2016 07:59 PM
hydroboost TO vacuum boost conversion xsv5ltr 1999 - 2003 7.3L Power Stroke Diesel 28 02-17-2016 02:53 PM
95 Powerstroke brake problem 49F1BIGBLOCK 1994.5 - 1997 7.3L Power Stroke Diesel 6 06-02-2012 12:19 PM
Tags
2003, 2005, 73l, 99, f250, f350, ford, location, mechanical, powerstroke, pump, reading, specifications, vacume, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
