VCT problem on 5.4lt triton - Ford Truck Enthusiasts Forums
Old 02-01-2010, 08:14 AM
TimmyG TimmyG is offline
TimmyG is starting off with a positive reputation.
I did the cyl heads on a 2005 5.4lt triton
my cam timing is dead on because the truck will idle perfect, as soon as i step on the gas pedal, the motor starts to run rough and I have codes for VCT too advance/too retarded. Has anyone encountered this problems when doing heads on those 5.4's. Is there anyway to reset the VCT system with the Ford scanner. Please let me know thank you
Old 02-01-2010, 09:01 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
i got 1 in my shop thats having the same issue.ive done 50 or so of these and havnt ever been kicked around like this.new phasers and chains and tensiners and have codes p0012 and p0021.its starting to make me mad.each time i tear back into it the timings off both cams.im gonna try removing all the followers and retiming the engine and crank it over without the plugs in it to prime the hydralic tensioners to see if the problem is the chains jumping with no oil pressure to them.just to let you know this teruck has been in 4 diff. shops and im stuck with it.ive subed new actuatior solinoids and a pcm for the issue because i hadnt rechecked my timing on the cams.ill let you know how mine turns out.hop[e you let me know how yours ends up.
Old 02-01-2010, 11:17 AM
I started my truck this morning, and it idles perfect, probably becasue over the weekend i lost the residual pressure in the VCT, and as soon as i touch the gas pedal it runs rough. Thats what boggals me the most is that it idles perfect after sitting for a awhile. any ideas on that on?? thanx
Old 02-04-2010, 08:52 AM
the vct system dosnt start to function until 4000 rpm or the second start up.i found that a prior shop had installed 2 left hand hyd. tensioners and both seals on them where cut.and i also had 1 that had collapsed completely.i ended up pulling all followers off and installed new tensioners.i spun the engine over to prime the system and they have heald in place and havnt jumped time.im in the proses of working on a few other vehicles and havnt had time to reinstll the fallowers and valve covers to see if it lives.ill let you know.
Old 02-04-2010, 11:57 AM
z 97ford1 z 97ford1 is offline
z 97ford1 is starting off with a positive reputation.
I'm not a engine builder but I've been reading all I can on these modular engines and have found out that you should "degree the cams". Would this make a difference?
Old 02-05-2010, 11:52 AM
i havnt gotten into the degreeing part of the triton engine yet,i assume its more for the performance/racing crowed.these engines have a mark on the cam phaser and the crank gear.this is where you line them up and dont have any other place to go.if they are out of time buy 1 tooth thenn the pcm will set a code for the vct over advanced/retarded,depending on which way the chain jumped.im sure in a performance area that the pcm can be tuned around this issue.
Old 02-06-2010, 12:50 PM
I'm just courious but, when you rebuild these 4.6's are you finding that you have to hold to the "extreme" tight tolerances that ford requires?
You know, cylinder wall to piston clearance .0005-.001 or .002 wall taper etc?
I don't even know how you can hold to these tolerances unless you use a tool die and mold shop to "edm".
Old 02-11-2010, 12:53 PM
Again, I'm no expert but my manual not only preaches about the timing marks but says to keep the cam "key" centerline perpendicular to the top of the head.
It shows this diagram in the manual many times with the timing marks.
I would think that if you keep the timing marks lined up correctly the cam key cl's would be lined up automatically????
It also says to use "ford oem" align tools. Cam holder and cam turning tool.
Lets us know.
Old 02-26-2010, 09:36 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
Those are not necessary unless you're doing a single cylinder head repair/change in-vehicle and do not wish to disturb the cam timing or retime both cams post repair. They're simply to assist factory techs and shops in saving labor time on repairs.
JL
Old 03-02-2010, 01:02 PM
Here comes the stupid quesition.
What is "VCT"??
Old 03-02-2010, 02:23 PM
What is "VCT"??
Variable
Cam
Timing
JL
vct seal on valve cover leaking oil? riverratba 2004 - 2008 F150 5 11-24-2012 07:36 PM
code P0021 charz 2004 - 2008 F150 1 08-24-2012 06:21 AM
06 5.4 3V Rattling and shaking ticking knock NOBODY SPEC 2004 - 2008 F150 7 01-26-2012 09:32 AM
04 f150 5.4 3V timing jumped P0345 VINZB Modular V8 (4.6L, 5.4L) 0 05-26-2011 11:08 AM
2006 F150 5.4 3V RATTLING AND SHAKING NOBODY SPEC 2004 - 2008 F150 0 03-21-2011 12:36 PM
Tags
2004, 2010, 46l, 54, 54l, 54lt, code, f150, ford, maquina, p0012, problems, solenoid, solinoid, timing, truck, vct
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
