Front turn signals not working
Old 01-31-2010, 04:18 PM
jquick1's Avatar
jquick1
jquick1 is offline
my front signals are not working. just bought this yesterday. i have replace the rear bulb sockets and the flasher relay(both). the rear work fine now(didnt work yesterday). the front park lights and emergency flashers work. just not the turn signals. 1978 F150 4x4 351m
Thanks For the help.
Old 01-31-2010, 05:07 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Does the dash indicators work?
Old 01-31-2010, 05:11 PM
jimbeam&coke's Avatar
jimbeam&coke
jimbeam&coke is offline
Go buy a tester and check and see if you are getting power. Then check for ground. Then clean the hell out of the bulb and socket and try again... Just my 2cents Hope it works
Old 01-31-2010, 05:35 PM
jquick1's Avatar
jquick1
jquick1 is offline
not getting power, checked all fuses, going to buy me a repair book tomorrow
Old 01-31-2010, 05:47 PM
81-F-150-Explorer
You need to answer my question on the dash indicators.
The dash indicators are hooked into the front turn signal wires. If they only work with the hazard lights, and not with the turn signals, then the turn signal switch is most likely defective.
If the indicators work with both the hazards and the turn signals, you have a wiring issue on the front of the truck.
Left Front Turn and Dash Indicator: Circut #3 Green/White Stripe wire.
Right Front Turn and Dash Indicator: Circut #4 White/Blue Stripe Wire.
You can check those wires with a test light at the bottom of the steering column for power as well.
The Front and rear turn signals are seperate in the turn signal switch, this is due to the brake lights sharing the same wires to the back of the truck. The fact that the hazards work in the front, also points to a defective Turn signal switch. You do not have a fuse issue, otherwise the back turn signals wouldnt work either.
Old 01-31-2010, 06:00 PM
jquick1's Avatar
jquick1
jquick1 is offline
sorry, no lights work on the dash. i took the dask out and most of the light are not even there.
Old 01-31-2010, 06:12 PM
81-F-150-Explorer
Ah, that makes diagnosis a little harder.
Still you can check for power at the column with a test light on the following wires with the ignition switch in the run position and the turn signal switch turned on to the left or right respectively.
Green/White Stripe: Left Front Turn and Dash Indicator
White/Blue Stripe: Right Front Turn and Dash Indicator
If no power, then it's got to be the TS switch.
boatordie
09-30-2016 07:44 PM
alecs
06-28-2015 09:39 PM
micklskot
16
04-04-2009 01:10 PM
Supercab
08-20-2006 03:23 PM
silverbullet99
1978 - 1996 Big Bronco
01-13-2004 05:12 PM
Quick Reply: Front turn signals not working
