how to identify my engine? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 01-31-2010, 05:17 PM
manyolcars manyolcars is offline
manyolcars is starting off with a positive reputation.
I need help with my engine but first I need to know what it is.
The truck is a 1988 Ford L-8000 with an 8 cylinder front sump Caterpillar engine that redlines at about 2600 RPM.
There is a sticker on the valve cover that has the number 0ZZ43319
I appreciate any help. Thank you
Old 01-31-2010, 06:57 PM
Big_Dom's Avatar
Big_Dom Big_Dom is offline
Big_Dom is starting off with a positive reputation.
The Cat website should be able to help you figure it out some way.
Old 01-31-2010, 07:36 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Probably a 3208
Old 01-31-2010, 08:12 PM
When I got the truck I could reach in and bump the key to start it.
It ran well.
Now I have to work the throttle just right to start it,
it runs rough and makes an enormous cloud of white smoke.
Any ideas what is wrong?
Old 01-31-2010, 08:28 PM
rbaker6336's Avatar
Check for fuel line leaks,sounds like it may be sucking air
also check for intank fuel pump
Old 02-02-2010, 12:50 AM
thank you.
(message too short)
Old 02-15-2010, 12:15 AM
FESuperDuty's Avatar
FESuperDuty FESuperDuty is offline
FESuperDuty is starting off with a positive reputation.
Sounds like an old 3208. As for the white smoke, does it smell really rich and burn your eyes? Your injectors may be dirty and not atomizing the fuel. The effect will be worse when the engine is cold.
Also, it could be caused by the ultra-low sulfur fuel we now have. The process used to remove the sulfur content also removes the lubricating properties from the fuel. This can cause premature wear in the injection pump and nozzles. I would run some really good fuel conditioner through it. I use Stanadyne fuel treatment in mine.
I am a heavy equipment mechanic, and one of my customers called me one day because he couldn't keep his diesel forklift running. When I got there, I checked the obvious, fuel filters, air filters, water in the fuel, etc. Everything looked OK. I asked him if he had been running fuel conditioner, and he said no. I gave it a heavy dose of Stanadyne and got it started. After about 20-30 minutes working the throttle, it smoothed out and ran fine.
What I mean by working the throttle is get it running, then throttle it up and let it idle down. Keep repeating this process for a little while. That will give the pumping mechanisms an other moving parts time to get lubricated.
Old 02-15-2010, 12:21 AM
Something else. If it is hard to start, it sounds like it may also be related to the low sulfur fuel. As you are cranking the engine the governor weights in the injection pump are supposed to open the fuel wide open for starting.
When the pumping mechanisms are suffering from a lack of lubrication, the weights may not be able to overcome the sticking, making it hard to start. Here again, hopefully the fuel treatment will help free things up after it has run awhile.
72 F-100 302 heads or engine Quentin10 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-27-2014 04:04 PM
need some help please chard17 1997 - 2003 F150 2 03-25-2014 07:10 PM
Need Help Identifying Engine Please VocaTexas 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-12-2013 08:07 PM
352 Engine? Rickys88 1961 - 1966 F-100 & Larger F-Series Trucks 18 11-23-2003 03:26 PM
81 Bronco - Need Engine Wiring Harness !!!!!!!! moneypit2 1978 - 1996 Big Bronco 3 06-12-2000 05:13 PM
Tags
3208, 98, cid, cover, decoding, engine, ford, id, identify, identifying, motor, motors, smoke, sticker, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
