Alternator - rebuild or replace - Ford Truck Enthusiasts Forums
Old 01-31-2010, 04:41 PM
Clint S Clint S is offline
Clint S is starting off with a positive reputation.
Hi
Just pulled my alternator as it quit on me.
One brush was shot and the other was down.
My question is this. There is a channel in the copper of the shaft of the alternator that is about 1/16" deep. I'm not sure how much contact surface is built onto the shaft so who might know if it's okay to just replace the brushes ($5.00) or do I have to replace the whole alternator ($285)
Thanks in advance.
Old 01-31-2010, 05:39 PM
1975IH200's Avatar
1975IH200 1975IH200 is offline
1975IH200 is starting off with a positive reputation.
The "copper" are the two slip rings where the brushes make contact.
I would polish those with a little scotch-brite and put the new brushes in.
Probably will last a long while.
You can always rebuild the alternator later if doesn't work out.
Old 01-31-2010, 08:09 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
I do commutators by wrapping them in a strip of emery cloth and pulling it back and forth. Works fine and knocks down irregularities quickly.
Old 01-31-2010, 11:21 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
if you have got about 150k miles or so, then the wear to the commutator is probably excessive. i have cut them down on a lathe and polished, put in new brushes... you wil bo o.k. for a few months. It about time for a new commutator... thats a lot of work, just get another alternator. You can get a better deal than $300. I bought a takeoff on e-bay from a guy that builds ambulance and puts on BIG units. It cost me about $100. a couple years ago.
Old 02-01-2010, 01:16 PM
Quote:
if you have got about 150k miles or so, then the wear to the commutator is probably excessive. i have cut them down on a lathe and polished, put in new brushes... you will be o.k. for a few months. It about time for a new commutator... that's a lot of work
Kinda what I thought as the commutator was pretty gouged.
Thanks guys
Old 02-01-2010, 10:33 PM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
I just put a lifetime warranty rebuilt from NAPA. It was ~$185, replaced the belt too for another $50.
Old 02-02-2010, 12:11 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
HI Clint,
If you would like to check out what we have here's a link to our alternator section.We sell new alternators,so there's no core charge to deal with.
Ford Truck Alternator
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Old 02-02-2010, 12:47 PM
z 97ford1 z 97ford1 is offline
z 97ford1 is starting off with a positive reputation.
I did a check-up on mine at 250,000 miles and found the brushes were only half worn, but, since I was in there I replaced them anyway. Everything else looked good so I reinstalled it back on and now I'm at 340,000 miles with no problems.
Old 02-02-2010, 09:58 PM
steve(ill)'s Avatar
your lucky. 75% of the alternators have the brushes and/ or commutator worn out by 150k miles.
Old 02-04-2010, 11:43 AM
Yea, my truck has ran so good it's unbelievable.
I know I will be rebuilding it soon.....I guess. Anyway, I went and looked at a used 97 for sale and noticed the engine running and could actually see a side to side shake in the engine.
I then went home, opened up my hood on my truck looked at it and I could not detect ANY movement at all. Makes me wonder if at the factory someone may have "blueprinted" my engine as an experiment.
Oh yea, I'm still on the original EGR, which I would have thought it would ruptured by now.
2002 f150 4.2 electrical issues jchandler11 1997 - 2003 F150 3 10-03-2016 05:09 AM
Bad alt or mystery draw? ZombieSlayer 1978 - 1996 Big Bronco 4 02-16-2014 12:34 AM
130 amp alternator ?? Hussler 1994.5 - 1997 7.3L Power Stroke Diesel 4 01-22-2011 02:38 PM
Squeaking Alternator geoaigel 1999 to 2016 Super Duty 12 02-28-2010 04:24 PM
3g alternator overcharging TourqueRise Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 01-16-2010 09:37 PM
Tags
03, 1997, 2001, 2004, 97, alternator, brushes, change, changing, f150, ford, rebuild, replace, tools, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
