Front door speaker size? - Ford Truck Enthusiasts Forums
Old 01-31-2010, 03:39 PM
jrodimus's Avatar
jrodimus jrodimus is offline
jrodimus is starting off with a positive reputation.
Hoping someone knows the speaker size in the front doors of a 1990 f250. Type and size would be nice. Mounting depth would be down right awesome. Its cold here and popping off door panels is asking for trouble. Thanks guys.
Jared
Old 01-31-2010, 03:44 PM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
Not sure on the depth,but if i'm not mistaken i believe it's a 6 1/2.
Old 01-31-2010, 04:07 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Quote:
Jared
Quote:
Yup...and a 5 1/4 will fit as well.
As far as depth, my door speakers are about 3.25" beep and they fit in with no problems. The only problem you may run into is where the tweets are mounted on the face of the speaker, they may be too tall. Look for a slimmer design on the face to clear the integrated grille on the panel.
Old 02-01-2010, 09:07 PM
cmcolfax's Avatar
cmcolfax cmcolfax is offline
cmcolfax is starting off with a positive reputation.
6 1/2"
Rear quarters are "Ford/Mazda" specific 6" x 8".
HTH
-cmc-
Old 02-01-2010, 09:52 PM
RustyGreen's Avatar
RustyGreen RustyGreen is offline
RustyGreen is starting off with a positive reputation.
A tip if you have tinted windows though, a simple fix to keep the speaker from possibly rubbing on the window is, simply put some washers between the speaker and the door to space it out and keep it from scratching your tint.
Wish I had known that before the person that put everything together in my old car.
Old 02-01-2010, 10:10 PM
jrodimus's Avatar
Thanks for the info.
Now on an unrelated to speakers note: I just found some new doors with power windows. Whats the chances the wiring harness is in my truck.(1990 f250) I have manual windows and locks. The power doors are in much better shape and I would sure like to use them. Maybe I should "New Post" this.
-Jared
Old 02-01-2010, 10:42 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
uhm it wouldnt be to hard to make them work.... there is a place in the fuse box that prolly has a fuse in it already just run ur hot wires from it... then run a hot wire from the drivers side door to the passenger side door switch and tie it with the hot wire so u can opperate both windows from the drivers side....
hope that makes sence to u
Old 02-01-2010, 10:54 PM
jrodimus's Avatar
Yeah. I know what your trying to say. I really didnt wanna break out the tester, wiring, crimpers, and swearwords for this one. But I may have no choice. Still probably easier than switching all my manual gear over to the good power doors though.
Old 02-04-2010, 09:23 AM
Itchy brother's Avatar
Itchy brother Itchy brother is offline
Itchy brother is starting off with a positive reputation.
You are better oof getting a split speaker setup for the doors!
I have 6 inch or so fusion splits which fit nicely behind the door panel!
I have the tweeters mounted on the ends of the dash next to the front pillars!
Old 02-04-2010, 10:11 AM
jrodimus's Avatar
I think you were reading my mind IB. My exact plan. Thanks for the suggestion.
Old 02-04-2010, 07:48 PM
Bovaloe's Avatar
Bovaloe Bovaloe is offline
Bovaloe is starting off with a positive reputation.
My pickup doesnt have speakers in the back. Was it an option? I have an XLT, I thought that was the "luxury" version
Old 02-04-2010, 07:56 PM
jrodimus's Avatar
Quote:
Wish I could tell ya Bovaloe. Someone else here will most definatly know. I just stripped a 1990 xlt diesel and honestly I dont remember.
Old 02-06-2010, 08:34 PM
cmcolfax's Avatar
Didja look in the cab corners behind the seat? They are hidden behind the plastic. At least that is where they are in my 92 XLT.
-cmc-
Old 02-06-2010, 10:10 PM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
The 87-91 standard cab trucks only had front speakers
Old 02-06-2010, 10:19 PM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
unrealtrip is starting off with a positive reputation.
Check out Crutchfield: LCD TV, Car Stereo, Home Theater, Speakers, Plasma TV they have a web config tool that will tell you what you can fit in your truck.
Front Door Speaker specs., 2011 Escape Limited Big-Red-Lariat Escape & Escape Hybrid 2 12-01-2016 02:17 PM
Speaker size 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 6 08-01-2012 11:31 AM
E350 Front door speakers trtinker 1968-2013 Full Size Vans 11 10-20-2011 06:17 AM
Door Speakers mtntop1 1987 - 1996 F150 & Larger F-Series Trucks 3 08-21-2009 10:59 PM
89 Speaker size? *fordtuff* 1987 - 1996 F150 & Larger F-Series Trucks 1 08-01-2008 05:49 PM
Tags
1992, 1995, 2001, 2005, 2006, 2008, door, f150, f250, ford, front, size, speaker, speakers, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
