cutting off exhaust - Ford Truck Enthusiasts Forums
cutting off exhaust
Old 01-31-2010, 02:20 PM
tx fisherman tx fisherman is offline
tx fisherman is starting off with a positive reputation.
cutting off exhaust
i have a 93 f250, and i was wondering if i could make a difference in the sound by cutting off the exhaust afteer it comes out of the muffler, i know the best way to improve sound weould be to cut off infront of the catalytic converter, but that not an option my dad would kick my @$$. so i was wondering if this would work, and if i could run into any problemns if i did it
Old 01-31-2010, 02:50 PM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
your just wasting your time imo,because the converters on these trucks are pretty restrictive and just cutting off your tailpipe is kind of dumb and it's not really gonna be any louder.It's just gonna sound like your exhaust rotted off.Even if you cut off the muffler and straight piped it,it would still be quiet.Just depends on what you wanna do and in your case how loud your dad will let you have it.
Old 01-31-2010, 04:13 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Don't hack up your exhaust.
Old 01-31-2010, 05:24 PM
94WhiteF250's Avatar
94WhiteF250 94WhiteF250 is offline
94WhiteF250 is gaining momentum as a positive member of FTE.
Honestly bud...I have a 94 F250 with a 5.8....I didn't want to cut the cat off due to the "awesome" emissions here on Long Island NY. So I junked the muffler and did a "Y" after the cat and I have duals coming out on an angle behind the tires. Honestly when I am just driving there is no cab noise and there is just a nice rumble. But as soon as I get my foot into it from a stop you can def. hear it coming haha.
Just my .02 cents here
Old 01-31-2010, 06:10 PM
thanks yall, its not the loudness thats the problem its the damn emmisions, i was just wonderin if i could do domethin without buyin a glasspack or somethin, i think im just gonna get a glass pack
Old 01-31-2010, 07:24 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
What engine do you have?
Old 01-31-2010, 09:57 PM
5.8, any suggestions on what glass pack and what size? lookin for one that sounds pretty sweet all the time
Old 01-31-2010, 09:59 PM
I personnally prefer Flowmaster 40s
Old 02-01-2010, 12:11 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I like Magnaflow. I will never own Flowmaster again. If you have both cats just Y it off the rear cat with duals and no muffler like 94WhiteF250 said. It sounds good. You could also put a glasspack in place of the muffler and that will sound pretty good too since you have the cats.
Just removing the tailpipe is a waste of time.
Old 02-01-2010, 12:32 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
Where we can get Y pipe?
Idiot engineer thought best idea is put 2 pipes weld to flat steel then bolt to flat steel to cat.
I would like keep quiet because it can be really loud when on highway due rot muffler on my F250. You would get tired of listen loud exhaust if you drive daily and average 20k to 50k miles per years.
Old 02-01-2010, 09:51 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Bassani 58150B2/58150B3 y-pipes are designed for 5.8L Broncos. They both fit the F-series just fine. One comes with a converter, the other does not. I purchased the 'B2 version so I could install a converter of my choice on my '92 F350 w/5.8L engine. This y-pipe is for those who want a 3" exhaust.
For those looking for something that is more easily adaptable to a stock exhaust Magnaflow makes a direct fit line of converters that also include the y-pipe. The 5.8L version is part no. 93312.
Old 02-01-2010, 11:21 AM
Ok found 2 y pipes.
But guy who measure exhaust pipe on muffler and say it 2 1/4"
I bought new stock muffler but they are 2 1/4 which is 2.5 so I want make sure I get correct y pipe.
But you say it 3" ??
here link Exhaust Pipes, Y Pipes - SummitRacing.com
2 1/4"
MagnaFlow 10768 - MagnaFlow Stamped Y-Pipes - Overview - SummitRacing.com
3"
MagnaFlow 10798 - MagnaFlow Stamped Y-Pipes - Overview - SummitRacing.com
97tugger 97tugger is offline
97tugger is starting off with a positive reputation.
A cheaper way would be to just cut the muffler out and replace that section from the cat to the tailpipe with a piece of pipe. This is cheap and will make it sound good and it keeeps the noise away from the cab. Personally i wouldn't put a glasspack in unless you wanted it to be fairly quiet. The cat will keep it quiet enough.
Old 02-01-2010, 11:31 AM
rla2005's Avatar
The stock exhaust pipe size from the converter back to the muffler on a F-series with a 5.8L is 2.25" or 2-1/4 inch. Same dimension, different scale.
Old 02-01-2010, 12:45 PM
Quote:
I mean exhaust pipe from engine is 2 1/4" ?
Should I cut the exhaust off? hwybee22 6.0L Power Stroke Diesel 45 10-03-2016 03:27 PM
do i have an 03' turbo? x15 6.0L Power Stroke Diesel 3 04-21-2011 09:25 PM
bronco exhaust fordbronco18 1978 - 1996 Big Bronco 41 12-09-2009 10:21 AM
exhaust question dixiemudder04 North Carolina Chapter 22 08-24-2008 09:32 AM
Which is louder 1993_f150 Exhaust Systems 11 03-22-2005 07:18 PM
Tags
1987, 91, bronco, catalytic, converter, cut, cuting, cutting, exhaust, exhuast, exuast, f150, f250, ford, muffler, pipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
