6 inch lift
thanks i have a short bed ext cab, v10 6 speed. so far im thinkin about putting together my own kit, most kits lift the rear 2 inches less and i dont want my truck to sit a lil low in the back, or the kits r very expensive. so far national tire and wheel has the best prices, what have u guys found out??
I reviewed the 6" lift kits at National Tire & Wheel. They carry the popular brands like Skyjacker, Pro Comp, Super Lift, etc. What is your budget for this lift kit? Do you plan to run 35" or 37" tall tires? What gears do you currently have in your axles? How long do you plan to keep the truck?
I've got an 05 crew cab with 6 inch lift running 35s. I shimmed the carrier bearing and had vibration, actually worst then it was stock. Took the truck to a driveline specialist and they told me to keep it stock form so I put it back and it drives like a dream. Go figure.
Running 35s your pretty close to stock so changing the gears is not necessary unless you just want more low end power. Anything above 35s and I would say yes to changing gears. Anywho just my two cents. Good luck
thanks
Shawn
thanks
Shawn
Installing 4.10 gears with 35" tires will get you very close to the same RPM's as you currently have with 3.73 gears and 31.5" tires. You can use the RPM Calculator below to determine which gears are best for your application. Your 6-speed transmission has a "Transmission High Gear Ratio" of .72.
RPM Calculator
Do you plan to keep the stock 16X7 wheels or use aftermarket wheels?
RPM Calculator
I Just ordered 35s on 20 x 10s w/ 4.79" BS. can I get away w/ 4" or do I need 6"?
Here is a 2004 F250 with a 4.5" (should be 4") Icon lift kit and 35" tires on 20" wheels.
Here is a 2004 F250 with a 6" Icon lift kit and 35" tires on 20" wheels.
There is not a noticable difference in these pics. You can go to the link (gallery) below and see the various configurations for more examples.
http://www.trucktoyzperformance.com/...earch-blue.php
BTW, what wheels did you order? That's an unusual BS for a 10" wide wheel...
IMO, a 4" lift kit looks better than a 6" lift kit with 35" tires. Now, if you do serious off-roading, you may want the 6" lift kit for better wheel articulation.
Wheels are Moto Metal 951.
