no signal to fuel injectors from pcm, replaced pcm and coils. - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-30-2010, 11:59 PM
976dave 976dave is offline
976dave is starting off with a positive reputation.
1997 Ford Expedition, PCM was replaced, along with both coils. I inject fuel manually an it runs but I dont have any signal from PCM, Red leg to injectors is hot.
Old 01-31-2010, 11:10 AM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
you need to check your pcm grounds to fire the injector the pcm gounds the circuit
Old 01-31-2010, 12:38 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
What is your THEFT light doing at key-on?
Early PATS systems worked by disabling the injectors....
Old 02-01-2010, 12:43 PM
I checked the PCM grounds and have no signal. The theft light continues to flash for an extended amount of time, longer than it used to, Do you think that it could be the key?
Old 02-01-2010, 12:44 PM
Gotta love Ron White!
Old 02-01-2010, 12:47 PM
fordtech08's Avatar
that could definetly be the case
Old 02-01-2010, 01:16 PM
Thank you for the quick response. Do I have to take the vehicle to the dealer or can I just take the key and reg?
Old 02-01-2010, 02:37 PM
fordtech08's Avatar
you have to have the truck at the dealership, where are you at?
Old 02-01-2010, 03:28 PM
san jose ca. thanks for the good advise
Old 02-01-2010, 03:37 PM
fordtech08's Avatar
oh little far for me to stop by with my computer
Old 02-01-2010, 05:35 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
"You can't fix stupid!" ?????
Old 02-01-2010, 07:14 PM
Quote:
Hey, I'm cynical from having to work with people with more cents than sense (but not by much). It's not directed at anyone specific here (usually, although I might make exceptions).
There's your problem. PATS is not proving out and the PCM thinks the truck is being stolen. Consequently, the PCM disables the engine.
Since you say you replaced the PCM, it's probably safe to say you did not follow the correct procedure in the workshop manual. Either reinstall the original PCM (if it is not defective) or tow it to a dealer for proper programming.
Technical help needed Rider48 Modular V8 (4.6L, 5.4L) 2 06-19-2015 10:26 PM
98 f150 no spark at coils and no fuel being injected MADMECHANIC1991 1997 - 2003 F150 9 01-12-2015 06:39 PM
PCM wiring diagram injector 1 no signal... rch10007 Modular V10 (6.8l) 5 10-01-2014 06:42 PM
Bad PCM? RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 9 02-25-2013 01:31 PM
fuel injectors have weak trigger signal lleonard1 1987 - 1996 F150 & Larger F-Series Trucks 8 07-09-2008 02:29 AM
Tags
02, 1997, 46, coils, control, expedition, ford, fuel, gpcm, injector, injector46, injectors, module, pcm, power, ranger, signal, signals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
