1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Child Lock on rear doors
Old 01-05-2010, 09:12 PM
wojolsc's Avatar
wojolsc
wojolsc is offline
I have a 2000 Navigator and the child locks keep self activating. I'll unlock them and before you know it my 13 year old is yelling at me to open the door. Is there anyway to keep this from happening. Has anyone else experienced this?
Wojolsc
The following users liked this post:
Old 01-05-2010, 11:52 PM
97ExpGuy's Avatar
97ExpGuy
97ExpGuy is offline
Wojolsc
It's a common occurrence for both Expeditions and Navigators. The only solution I can think of is A) don't slam the doors so hard (seriously - the force of slamming it forces the tab upwards to the lock position) or B) put in a piece of rubber to keep it from moving.
Old 01-06-2010, 08:55 AM
alloro's Avatar
alloro
alloro is online now
Received 4,178 Likes on 2,421 Posts
I put my switches into the unlock position then drove a black screw into each. They haven't moved since.
Old 01-06-2010, 03:33 PM
npearman's Avatar
npearman
npearman is offline
Mine does the same thing. Kind of aggravating. Think I might try the screw or rubber piece method.
Old 01-06-2010, 05:45 PM
kerim1's Avatar
kerim1
kerim1 is offline
i had the same problem with my 2000 expy i used a pice of rubber and it works great
Old 01-06-2010, 07:51 PM
1whoseeks's Avatar
1whoseeks
1whoseeks is offline
Wojolsc
Remove the yelling child. Problem solved.
Old 01-06-2010, 07:57 PM
alloro's Avatar
alloro
Better yet, leave the child and go inside to your recliner for some peace and quiet.
Old 01-08-2010, 10:28 AM
mikecox1's Avatar
mikecox1
mikecox1 is offline
That's just wrong!!!...... I have never wanted to do that
Old 01-08-2010, 11:14 AM
heterodox1's Avatar
heterodox1
heterodox1 is offline
I've never tested this out but I thought I noticed this one time... If the kid is pulling on the door handle (trying to open the door) when you hit the unlock button, it throws that little safety switch. This used to happen to me a lot but since the kids got the cell phones and video games, they are not in such a hurry to get out of the car anymore.
Old 01-08-2010, 11:51 AM
1whoseeks's Avatar
1whoseeks
You can train your child. After multiple times of locking them in because they are not aware of the real world, they can begin to see the cause and effect of their actions. If you let a child lead then who is the parent?
And yes if you pull the interior or exterior the door as you lock unlock with the driver door control panel or key fob the door will default to the lock position.
Old 01-08-2010, 09:51 PM
wojolsc's Avatar
wojolsc
wojolsc is offline
Remove the Yelling Child
This would upset the child since she likes the Nav more than I do. But the piece of rubber or screw sounds good. I've had many Mercs and Lincolns with this feature but never experienced this problem until the Nav. Oh well......I drove it in the snow for the first time today. It was like the snow wasn't there. For that experience its worth this little frustration. Thanks for all the feedback...at least I know I'm not the only one.....
Peace! Wojo
Old 01-31-2010, 12:50 AM
chano1965's Avatar
chano1965
chano1965 is offline
mine were doing the same thing, along with the electric locks going up and down slow or not at all. I sprayed the switch with good ole WD-40, one door I needed to pull the door panel off to lube the lock thingy (techicnal term)
Old 02-01-2010, 10:40 PM
ArgoExpedition's Avatar
ArgoExpedition
ArgoExpedition is offline
I actually pulled the door panel and kept tweaking the attached rod until the latching stopped. Part of the problem is slamming the door, and mostly with mine it was every time you used the inside door handle would cause the switch to slowly move to "lock" position. It would take anywhere from two pulls to about 4 pulls before it was locked again. Just a slight more, or less, bend at the existing bends and problem was solved. two years so far without a single incident.
Of course the screw thing works too and is a lot easier.
Redneckfordf2502002
06-03-2013 10:05 AM
the4by4freek
27
12-04-2012 10:48 PM
chicagodragon
27
12-01-2011 04:14 PM
wojolsc
Large Truck
09-01-2010 12:34 AM
wojolsc
12-16-2009 10:39 PM
Quick Reply: Child Lock on rear doors
