03 excursion v10 with 65k 4x4 problems - Ford Truck Enthusiasts Forums
Old 01-30-2010, 09:03 PM
jquick1 jquick1 is offline
jquick1 is starting off with a positive reputation.
i was leaving my yard earlier(ice strom today) put it in 4x4 worked fine. went to pick up my son at girlfriend and put in 4x4 to get in drive way and it would not work. tried it 5more time on the way home and when i got home and nothing. i hear it clicking but no 4x4. it done this one time before.
Old 01-30-2010, 11:25 PM
esaycho esaycho is offline
esaycho is starting off with a positive reputation.
I assume all the excursion's have the Electric shift system, so when you change the **** does the heater go to the defrost setting. If so you have a vacuum leak and the hubs are not being auto engaged. At the front wheels manually turn the selector from auto to lock, and then see if the 4x4 works
Old 01-31-2010, 12:21 PM
chinook507's Avatar
chinook507 chinook507 is offline
chinook507 is starting off with a positive reputation.
Sounds like it could be the shift motor on the Xfer case.
Old 01-31-2010, 08:44 PM
RSQ4x4's Avatar
RSQ4x4 RSQ4x4 is offline
RSQ4x4 is starting off with a positive reputation.
I bet its the hubs, like before mentioned, manually engage the front hubs. If not check for vacuum leaks and if you don.t find any the lovely expensive seals behind the front hubs are probably bad.
4x4 dash light blinking very fast! sa_hobbit 1997 - 2003 F150 1 02-14-2015 05:20 PM
might be done with this truck riden82 6.7L Power Stroke Diesel 24 01-03-2013 08:19 AM
Need some info/help Vinford 1999 - 2003 7.3L Power Stroke Diesel 3 10-24-2012 10:10 PM
4X4 not disengaging GeneralC. 1999 to 2016 Super Duty 9 06-03-2008 08:27 PM
need help with 99 expedition 4x4 2000gpr 1997-2006 Expedition & Navigator 14 02-14-2007 11:21 PM
Tags
03, 2002, 4x4, excursion, excursions, ford, problems, system, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
