2006 f-250 engine block heater - Ford Truck Enthusiasts Forums
Old 01-30-2010, 07:40 PM
rhrs2414's Avatar
rhrs2414 rhrs2414 is offline
rhrs2414 is starting off with a positive reputation.
hey guys, got a quick question, ive got a 06 f-250 diesel, the temp is dropping below 10 degrees tonight, and im at work, i was able to walk outside and take a quick look behind the bumper and couldnt find a plug. was just wondering if there was a way to check by vin# if my truck is equiped with the plug, or if i have the engine block heater and have to add the plug. please dont think im lazy, i work at the 911 dispatch center and dont have the time to spend outside tonight laying on the ice under my truck!!! thanks in advance
Old 01-30-2010, 07:43 PM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
All the superdutys have the block heaters. But the plug is a option. Its $105.00 at the dealership. I got my plug yesterday and the techs gonna install it since my truck is in the shop.
Old 01-30-2010, 08:02 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
You might want to check this thread out....
http://www.ford-trucks.com/forums/91...ml#post8343162
Old 01-30-2010, 08:13 PM
phish555 phish555 is offline
phish555 is starting off with a positive reputation.
Yes you have the block heater, but like already stated, you need to buy the cord to be able to plug it in. It also needs to be routed correctly. Nothing you will be able to do tonight. However as long as you have no faulty injectors, you should be able to start it just fine in the morning.
Old 01-31-2010, 12:31 AM
theonlypheonix theonlypheonix is offline
theonlypheonix is starting off with a positive reputation.
Quote:
agreed, no faulty injectors or FICM, or weak batteries and with syn 5W-40 oil you should be good to go down to at least -10 F without a block heater. Although its really painful to hear all the fuss a 6.0L PS makes when it starts cold.
2015 F-150 block heater tripping GFCI R3lyc 2015+ F150 39 03-14-2017 08:46 PM
6.2 Block Heater (2015 F250) JM96F250 1999 to 2016 Super Duty 13 01-09-2015 08:00 PM
Digital temp gauge not working. tadpole68 1999 to 2016 Super Duty 3 11-24-2013 08:47 PM
block heater b_man360 Ranger & B-Series 2 12-30-2010 12:35 AM
Block Heater Failure! Airzima 6.0L Power Stroke Diesel 22 12-11-2009 10:43 PM
Tags
2004, 2005, 2006, 60l, block, diesel, engine, f250, f350, ford, heater, install, location, long, plug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
