Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-30-2010, 07:28 PM
562dragnhra's Avatar
562dragnhra 562dragnhra is offline
Garage is empty, add now
562dragnhra is starting off with a positive reputation.
HHO
hi, i biult my hydrogen generator, but dnt know how to hook it up on my 6.9 Turbo diesel, the electrical part i got but the plumbing i dnt know, any help guys??????
__________________
1977 F250 6.9 BANKS Turbo Diesel "Intercooled" with an Allison AT545 4 speed auto, 3.00 gears, 33" tires
  #2 (permalink)
Old 02-25-2011, 09:20 PM
Crawler374 Crawler374 is offline
Crawler374 is starting off with a positive reputation.
In your intake. Simple as that. I would suggest putting it wherever your intake hose clamps to your intake.
  #3 (permalink)
Old 06-07-2011, 09:45 PM
Marianna2003 Marianna2003 is offline
1992 Ford F-350
My Garage
Marianna2003 is gaining momentum as a positive member of FTE.
I would drill and tap a hole right after the torbo to hat connection. There will be a lot of turbulance coming out of the turbo to mix blend the HHO & air. When you get it up and running, please post your results.
__________________
  #4 (permalink)
Old 06-15-2011, 07:10 AM
ohfloyd ohfloyd is offline
ohfloyd is starting off with a positive reputation.
Wouldn't you want this on the between the air filter and turbo? If you connect it after the turbo it will get pressure from the turbo as it spins up.
  #5 (permalink)
Old 08-13-2011, 09:35 PM
1992 Ford F-350
My Garage
Sorry, you're right not on the pressure side. Good catch.
__________________
  #6 (permalink)
Old 08-14-2011, 06:53 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Oh goodness, here we go again with this stupidity....
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #7 (permalink)
Old 08-15-2011, 11:29 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
Quote:
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
Tags
2004, 300, 58, 62, clubs, ct, deisel, diesel, econoline, enthusiasts, f150, ford, generators, hho, nj, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
