1979 Ford F100 351M Emissions/Vacuum Diagrahm - Ford Truck Enthusiasts Forums
Old 08-30-1999, 08:55 PM
Bob_1 Bob_1 is offline
Bob_1 is starting off with a positive reputation.
I need help obatining a copy od the emissions/vaccum diagrahm for my 1979 Ford F100
351M engine with 2 barrel carb.
thanks
Old 08-31-1999, 12:34 PM
john john is offline
john is starting off with a positive reputation.
I just went through this with the 400 on my 1978 Ranchero GT. The problem is that the routing often varies within model years. You should have a VECI diagram underneath the hood somewhere that shows the correct routing for your specific car. If this is missing (like mine) was you need to find a copy of the repair manuals printed by Mitchell's. This is the only place I was able to find that actually has a compilation of the various routing options for each engine type. Check with your local public library (which is where I found mine) and see if you can make a copy. If this doesn't work email me and I can try to get you a copy via fax or snail mail.
Old 08-31-1999, 04:05 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Please update your user profile within 24 hours with a valid email address. I don't like bounced email in my inbox for the notifications being sent out to you whenever someone posts.
Old 09-02-1999, 12:07 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
I restored a 78 ford supercab low boy. Recently I found a set of factory high boy springs, and installed them. I'm running 33 12.50 16.6 BFG A.T. When I installed the springs it turned my steering wheel about 180 degrees. Not having a adjustable drag link, I took off the steering wheel and centered it. The truck wants to track every crack in the road, and steering is very eratic. I have replaced worn tire rod ends, tires balanced, replaced king pins etc... My thinking is that I have a steering box off center, and I don't have a way to adjust the drag link arm. I can not seem to find anyone that carries an adjustable drag link for a 3/4 ton truck. Has anyone had this problem when installing a lift kit, and what did you do to fix the problem?
Old 09-02-1999, 11:02 AM
Charles Charles is offline
Charles is starting off with a positive reputation.
Emission Control System '79 F-100 302 Bewildered33 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-24-2015 07:47 PM
Need some help from the best? 1979 f250 4x4 SnowFighter Dirtyweekender77 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-07-2015 11:38 AM
Stock stock stock 1979 351m? Should I gut this baby thundersnow70 1973 - 1979 F-100 & Larger F-Series Trucks 19 12-27-2014 11:38 PM
1979 Ford F100 Air cleaner housing Redneck Romeo Air Intakes, Air Filters & Ram Air 3 10-14-2014 08:31 AM
emissions or smog parts topherchanin 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-13-2014 01:24 PM
Tags
1978, 1979, 1979ford, 351m, 400, 78, diagram, digram, emissions, f100, ford, ranchero, routing, vacumm, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
