1979 F-100 Ranger XLT For Sale - Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Old 01-30-2010, 04:55 PM
dentside79's Avatar
dentside79 dentside79 is offline
dentside79 is starting off with a positive reputation.
Year: 1979
Make: Ford
Price: $8500
Mileage: 138000
Color: Med. Blue / Silver Tri-tone
Private or Dealer Listing: Private Listing
Location (State): NC
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Blue
Engine: 351M 5.8L V8
Totally original 1979 F-100 Ranger XLT Reg. Cab Long Bed. 351M 5.8L V8 w/ C-6 Automatic.
All the following were installed in the last 5yrs. ALL RECIPTS AVAILABLE
Restoration Parts Installed – (80% NOS or Motorcraft Replacement Parts)
Mechanical – Rebuilt engine at 105,000mi. (Currently 138,000 on truck and 33,000 on original engine) Replaced Harmonica Ballancer, Flywheel, Starter, Starter Solenoid, Duraspark Modual (new one put on 1-25-10), Voltage Regulator, Battery, Waterpump, Belts, Steering Pump, Steering Gearbox, Power breaks Booster and Master Cylinder, Rear Wheel Cylinders, New Copper Steel Exact Replacement Radiator NOT A PLASTIC ONE AND NOT A REMAN!, Front Rotors and Pads, Rear Drums and Pads, Tires, Exhaust (true dual w/ side exits and 50-series flowmasters), Transmission Modulator Valve, Power Steering Pump to Gearbox Hoses, Radiator Hoses and Cap, AC/Heater Blower Motor, Heater Coil, All Hoses and Vacuum Lines, Heater Flow Valve. Ignition Coil, New Front axle bushings (all), New Drag Link and Tie Rod, New King Pins and Bushings, New Front Coil Springs, New A/C Accumulator, New A/C Evaporator, New A/C Suction and Discharge Hoses, New Expansion Valve, New Compressor and New Clutch, Retrofitted from R12 to R134a Coolant, A/C Idler Pulley, plus many more.
External Body Parts - Front Center Grill and Headlight Doors (Chrome), Front Bumper and Bumper Guards, Headlights, Cowl Emblems All, Rearview Mirrors, Anti-Rattlers, Fuel Cap, Gas Door Bumpers, Tailgate Lower Molding, Tailgate Bumpers, Rear Bumper, Licenses Plate Lamps (Ford Script NOS), Taillights, Taillight Moldings, 25% Body Work and repaint, New Hub Caps, OEM Radio Antenna (Tear Drop Mast), Firestone FR380 White Walls w/ 15kmi. on them.
Interior Parts – Door Panels, Window Crank Handles, Door Lock *****, Bezels (All including Glove Box), Dash Pad, Seat, Seat Back Pivot Covers, Glove box Liner, Ignition Switch and Tumbler, Dome Light Bezel and Lens, pedel covers, plus more....
The following spair parts go with the truck!!!......
D5UZ-13404-A Taillight Assy. - OEM New 2
D5UZ-13405-A Taillight Assy. - OEM New 1
SW-263 Dimmer Switch - Motorcraft New 1
RT-351 Thermostat – Motorcraft New 1
SW-1517 Tumbler/cylinder w/ keys Used 1
RS-62 Radiator Cap – Motorcraft New 1
30088 Thermostat 180deg. – AM New 1
C3TZ-15072-A Cigarette Lighter Lamp Assy. – OEM New 1
EV-68-C PCV Valve Assy. – Motorcraft New 9
E7AZ-6A892-A PCV Valve Rubber Grommet – OEM New 6
D9TZ-9A758-A Throttle Cable – OEM New 1
85898 Headlight/Taillight Repair Socket – AM New 1
D1FZ-13234-A Headlight/Taillight Repair Socket – OEM New 2
F-14474-1 Ignition Coil Repair harness w/ Clip – AM New 1
D3TZ-1022448-PR Door handle scuff pads (set of 2) – OEM New 1
NONE Vacuum Advance Mounting Screws – AM New 2
378437-S Gas Filler Door Bumper – OEM New 1
C5ZZ-9760-B Throttle Pedal Spring – OEM New 1
C6AZ-6206066-A Glove Box Door Rubber Bumper - OEM New 3
C7SZ-47A604-A Windshield Washer plastic Tee Fitting – OEM New 1
C5AZ-6262753-BA Seat Back Adjustment **** – OEM New 1
NONE Spare Tire U-Clip for Eye Bolt – AM New 2
379366-S Gas Filler Door Hinge Bumper – OEM New 2
219212003 Instrumentation Bulbs (Vermeer) – AM New 10
NONE Front Fender Apron Push on Plastic Clips – AM New 4
NONE C-6 Transmission dipstick tube o-ring – AM New 4
C7TZ-81060A08-A Glove Box Door Cable – OEM New 1
C6AZ-6206069-A Glove Box Door Spring – OEM New 1
E6AZ-5421952-A Tailgate Handle Linkage Plastic Clips – OEM New 2
SUBK-3345-K2 Taillight Chrome Molding Mounting Screws – OEM 4
NONE Cowl Emblem Plastic Bushings New 7
FL-1A Oil Filter – Motorcraft New 2
FA-97R Air Filter – Motorcraft New 3
FT-52 C-6 Transmission Filter kit - Motorcraft New 2
DU-1-A Distributor Stator Assy. - Motorcraft New 1
D3TZ-3A131-C Tie Rod Ball Joint w/ stud – OEM New 1
FA-675 Crankcase Breather Filter and Housing – Motorcraft New 2
YG-136 Heater Control Valve – Motorcraft New 1
FC-812-A Fuel Filler Cap (Non-locking) – Motorcraft New 1
E1AZ-9030-A Fuel Filler Cap (Locking) – AM Slightly Used 1
FA-678 Crankcase Breather Replacement Filters – Motorcraft 3
D6AZ-6D008-A Engine Block Heater Assy. – OEM New 1
FG-44B Fuel Filter Kit – Motorcraft New 6
D3TZ-1042084-A Rear Window Rubber Seal w/o grove – AM New 1
D3ZF-9C611-DA Decal – Breather Lid “351-2V” – AM New 1
NONE New Vehicle Window Sticker – OEM New 1
NONE Decal – Valve Cover “Power by Ford” – AM New 1
NONE Tag – Radiator Anti-Freeze Warranty – OEM New 1
DZ0009 Decal – “Unleaded Gasoline Only” – AM New 1
D5UA-17A083-BB Decal – Jacking Instructions (73-77) – AM New 1
D9TA-17A083-CA Decal – Jacking Instructions (78-79) – AM New 1
DF1287 Decal – Glove Box Door Inner – AM New 1
D9BH-19A688-BA Decal – AC Charge (Climatizer) – AM New 1
D1AA-19A688-AC Decal – AC Charge – AM New 1
D7AE-8057-AA Decal – Anti-freeze Fill New 1
D80E-9C485-AF Decal – Emission Control (78-351M) New 1
NONE Locking Hood Latch (Latch Only) – OEM Used 1
NONE Locking Hood Latch Handle (Damaged) – OEM Used 1
D9TZ-7228-B Tilt Steering Wheel Selector Collar – OEM New 1
There is a small area of rust on the passenger side bed fender area and along the bed back panel weld. There is also a small amount along the drip rail area. The cab top is starting to fade and needs painting. Other than that, the trucks body is EXCELENT! VERY SOLID TRUCK! See links to videos below.
http://www.youtube.com/watch?v=7HZd9tpLkpI
http://www.youtube.com/watch?v=zNi8Bu2VqDw
http://www.youtube.com/watch?v=g51g4_55Y7Q
Asking $8,500 OBO / Sorry, no trades. North Carolina truck since new.
Please send a PM, post a reply, or email me at s197man@gmail.com. Thanks.
Old 01-31-2010, 12:08 PM
dentside79's Avatar
Last and Finial offer - $7,500 and still includes all spare parts!
Old 09-26-2010, 12:24 AM
acreature's Avatar
acreature acreature is offline
acreature is starting off with a positive reputation.
Do you still have this Truck?
Old 09-26-2010, 09:18 PM
dentside79's Avatar
I never did get a chance to sale it. Long story short, I totalled it in an accident back in April. Since I had it highly insured, I sold it to the insurance company. So, no I do not have the truck any longer. Sorry.
Old 09-26-2010, 09:21 PM
dentside79's Avatar
Trucks life ended on April 23rd thanks to some dude who forgot to look both ways before pulling out. So, no truck to sale any longer.
Old 12-03-2010, 08:18 AM
Fordy123 Fordy123 is offline
Fordy123 is starting off with a positive reputation.
contact info please.
Tags
1960, 1979, 4wd, 78, az, e7az6a892a, f100, f150, ford, interior, parts, ranger, sale, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
