radius arm bushings
radius arm bushings
i just bought this truck about a month ago and the radius arm bushings are bad.
I'm trying to get them off without torching the rivets off and down that path because i dont have the tools to do so. Ive been trying to pull the axle forward with a ratchet strap but its not working.
so if anyone can help it would be greatly appreciated.
Received 5,160 Likes
on
I've done them many times using a ratcheting strap to pull the radius arm forward. Put the side on which you're working on a jackstand. Hook one end of strap to the very front of the frame, and the other end to one of the holes in the side of the radius arm. Ratchet away until you've moved the radius arm forward enough to work the bushings around the bracket. Usually it slides right back in the bracket when you back off the ratcheting strap. If it doesn't, no big deal. Just move the other end of the ratcheting strap to the back of vehicle and reverse the pull.
Nah....it's only about three inches and that only equates to about a 15-20 degree roll in the axle pivot bushings.....well within their tolerance. Same is true for the spring and shock mounts, at least on the F150. Thinking about it, I've never done it a leaf spring front end, so that may require a couple of other things being disconnected. But on the coil spring front ends its pretty darn easy and doesn't hurt anything.
I cut alot of the rivets off on my truck , the rivets on the radius arm brackets & all the rivets on the rear spring hangers when i lowered the truck , i tried everthing , air chissle , grinder ect & found the easest & quckest way was to cut a notch in the rivet with the air chissle then cut it off with a sawzall with a long good quality blade...Lew
LITTLE BLACK TRUCK
27
08-13-2015 02:30 PM
fordsuperduty250
03-02-2013 11:27 AM
topfisherman
1978 - 1996 Big Bronco
06-10-2004 10:48 PM
