C6...can't feel or shift into 1st gear
Seals are very inexpensive. If you are taking the trans out and tearing it down I would spring for a master rebuild kit. It's not too expensive, either, and it doesn't make sense to tear the trans down and only fix the seals in one clutch. If one set is worn out, the others are probably not far behind. And the frictions should be changed, too, and come in a master rebuild kit.
Diytinkerer
1997 - 2003 F150
05-19-2017 10:34 PM
whatusername
05-04-2016 09:12 PM
shultzaberger
1983 - 2012 Ranger & B-Series
17
03-30-2016 07:47 AM
cchighman
Escape & Escape Hybrid
09-11-2014 09:15 PM
