6.4 Liter New Fuel Filter - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-30-2010, 10:12 AM
Master Drago Master Drago is offline
Master Drago is starting off with a positive reputation.
I picked up a new fuel filter for our '09 F250 Super Duty (6.4 liter diesel) at O'Reilly Auto Parts - they showed it as a Wix 33950 two part kit. I also went by the Ford dealer to get old kit for the 6 liter I traded in exchanged - they gave me a FD-4609 (8C3Z-9N184-A). When I got them home I found that the water separator (HFCM) filters are different on the end that goes in first (opposite the cap end). I took an image - http://i355.photobucket.com/albums/r...m/DSC_0008.jpg - so all can see the problem. Does anyone have any ideas if Ford changed something? I guess I can just take the old one out and stick the matching one back in. The odd thing is that on fordparts.com the illustration exploded view has the Wix variety.
Thanks for any input.
Kenneth Drake
Willis, Texas
Old 01-30-2010, 10:19 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Yes Ford changed the primary fuel filters in order to deal with the injector issue. What happens is that the filter would get clogged and the fuel would look for another way in and go underneath the filter, so the filter wasn't actually be used. Ford put that second O-Ring in there in order to force the fuel to still go through the filter. Thing is, you need to be more **** about upkeep with regard to filters otherwise, you'll run into pump issues and one helluva sucked in filter(I've seen them). Boy I'm glad I don't have to worry about the primary anymore.
Old 01-30-2010, 10:56 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
i would take it back and get the ford OEM ones, they will be correct in fit and filtration requirements.
The 6.4 is too finacky (spelling?) to take a chance on it working.
Old 01-30-2010, 10:59 AM
tex25025's Avatar
Oh crap, I missed the part about the 6.4 filter(need to have my glasses checked I reckon), disregard my earlier post. That was in reference to the new 6.0 filters.
Old 01-30-2010, 11:02 AM
senix's Avatar
Quote:
Still good advice:
WIX/Visteon Air Filter Easier to Change & Higher Capacity autoparts 6.0L Power Stroke Diesel 34 10-25-2013 01:14 PM
E fuel question 96ford250 1994.5 - 1997 7.3L Power Stroke Diesel 58 08-07-2012 06:35 PM
new Water seperator vfelix702 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-30-2011 01:26 AM
Not going to use Pennzoil Longlife again Kenworth 6.0L Power Stroke Diesel 10 05-20-2007 12:39 AM
WIX Updates Fuel Filters For 6.0L (Wrong Part #)!!!! - URGENT INFO!!! Beachbumcook 6.0L Power Stroke Diesel 30 04-02-2006 09:29 AM
Tags
08, 33950, 64, 8c3z9n184a, diesel, filter, ford, fuel, issues, kit, problem, problems, pump, water, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
