Louisville
02-11-2010, 12:28 AM
Quote:
Originally Posted by
bigrigfixer
Check the drain *****. They might not be seated properly, or if they're the twist type, might not be closed.
There might be a leak in the compressor discharge line.
The governor might be bad. Or, you might need to put an unloader kit in the compressor.
Keep us updated.
I cant hear any leaks anywhere.
When I open the valve on the airtank nothing comes out.
Ice in the lines?
02-11-2010, 10:44 AM
Easy way to find air leaks is to charge the system with a separate compressor.It's offen hard to hear a leak with the engine running
02-11-2010, 10:53 AM
rbaker6336
Good idea .................your going to make a trucker out of me yet!
Diesel_Brad
Large Truck
01-31-2016 11:35 AM
phoenite
New Member Introductions
10-20-2015 02:37 PM
JRon
Kentucky Chapter
05-19-2015 09:16 PM
5plusfordtrucks
Large Truck
13
01-06-2015 06:46 PM
12 ,
1974 ,
24 ,
8v71 ,
budd ,
ford ,
headliner ,
kind ,
l9000 ,
louisville ,
mufller ,
older ,
page ,
system ,
tranny ,
truck ,
trucks ,
volt
