What makes my f250 an HD?
Old 01-31-2010, 11:10 PM
capn kirk's Avatar
capn kirk
capn kirk is offline
Originally Posted by DIYiT
I've come to the understanding that the F250 HDs were the exact same as an F350 except for the Dana 50 TTB vs the solid axle (and a different rear axle block). F250 LD were the same as the F150 except for the heavy duty rear axle, and possibly a dana 50 TTB rather than dana 44 TTB. Frames from 250HD were the same as 350, 250 LD to 150.
thats about what i have come to understand except i think the 150 has a different frame thats why you cant get it with crew cab long bed the 250LD i dont know if it was on the 1/2 ton frame or the bigger one
Old 02-01-2010, 12:05 AM
swervin's Avatar
swervin
swervin is offline
So will a dana 50 fit where a 44 is. As in my f150 has a 44 and i would like to put a 50 in because you can get them out of a junk yard with 4.10s. If its a beefy 44 then it should fit?
Old 02-01-2010, 12:37 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Milwaukee1979F150 is offline
No
not worth it easy to put dana 44 solid axle.
Why Dana 50 require leaf spring so more work to make it.
my 95 F250 XL HD have 50 Dana it look beefy if you compare to F150 or Bronco.
09f250hd
6.4L Power Stroke Diesel
34
02-28-2014 03:13 PM
stanglver1511
12-16-2013 07:14 AM
nonrev321
09-08-2012 01:37 PM
Johnny L
73
12-09-2011 07:49 PM
carpe_diem
1999 to 2016 Super Duty
13
12-07-2003 10:03 PM
Quick Reply: What makes my f250 an HD?
