Power Steering Problems! Help! - Ford Truck Enthusiasts Forums
Old 01-28-2010, 02:56 PM
Matt_S Matt_S is offline
Matt_S is starting off with a positive reputation.
I have a 2000 Excursion with a 7.3L. I have an Airaid Intake and my tire size is 325 75R16. My wheels are also 10" wide. I've been through 3 power steering pumps since I've put these tires and rims on. My Ex is currently sitting in the shop at the local Ford Dealership trying to figure out why my latest pump went out nearly 24hrs after installation.
Local shop (not Ford) told me this,
"It's your gear box. It's over heating because it's going bad and causing your pump to go bad as well. It will cost $497 to replace."
How do I fix this problem? I've been told to upgrade the pump. Then I was told that won't help. I was told to change the pulley and make the pump work harder. Then I was told that will burn up the pump faster.
What have you all done to yours? Or have you heard of this happening before?
Thanks guys,
-Matt
Old 01-28-2010, 04:23 PM
ukmat71's Avatar
ukmat71 ukmat71 is offline
ukmat71 is gaining momentum as a positive member of FTE.
can i ask what it feels like when your pump has gone.
as mine drives fine until every now & then when i make a quick turn the steering seems to lock and turn really slow, i am thinking my pump is on its way out, but then its fine for weeks.
Old 01-28-2010, 06:49 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
All of the bad gear boxes I've had either failed and not had power assist or had bad spots where it steered fine but either didn't return to center or lost power assist for a few degrees of rotation.
Old 01-29-2010, 10:16 AM
ukmat71- It depends on how far gone your pump is. It starts with the steering getting incredibly difficult to turn unless your on the roll. You should also hear a whine when you turn. Eventually you'll lose power brakes as well. Of course, for an Excursion, that's not a good thing at all.
ReAX- I'm not having those issues at all. It's definitely my power steering pump. I just don't understand why I've gone through so many. I don't hear of other lifted trucks having these problems.
Old 01-29-2010, 01:52 PM
ReAX's Avatar
I just had to replace my PS fluid because I had no power assist on concrete while stopped. It's mostly come back, but I suspect it's getting close to pump time. What kind are you using as the replacements (this can have a big impact)?
A1 Cardone is usually pretty good reman, but those new china units can be iffy.
Old 01-29-2010, 04:02 PM
ukmat71's Avatar
mmmm cheers guys, may be i have some crud in my fluid then , as it really is only now and then , i usually kick the gas for a second and its cleared.
i'll try to flush the system out soon and see it that makes a difference.
back on topic now
just noticed you said lifted truck , could this be a problem with the steering rack binding as the angle will be different from the point where it meets the steering wheel (sorry cant think of the word but you know what i mean, hopefully)
pinion i think , yes rack and pinion , if you have lifted it i would imagine that the steering rack has got to be adjusted somehow to accomodate for the greater angle as the wheels are lower than the body.
Marcus
Old 01-29-2010, 04:05 PM
ukmat71's Avatar
actually forget rack & pinion , the ex uses a diferent system i think ?
but if its lifted then the problem will be similar i would imagine.
Old 01-30-2010, 07:55 AM
ReAX's Avatar
Our platforms don't use the rack and pinion style steering. It's a gear box with a pitman arm and drag links. The sharper the angle on the drag links, the more force it takes to push the spindles. However lift kits over 4" usually either come with or recommend a drop pitman arm to correct this to some degree, it's not a fix but more of a bandaid that works decently.
The fact is, big tires and lifts make things difficult for the power steering system. I'm only running 315/75r16s on stock wheels and my fluid only last a couple of years. My truck does have a power steering fluid cooler and I've considered upgrading it to a full sized transmission cooler.
Excursion XLT 4x4 v10, 8" Lift with 37" tires rmrichards949 Vehicles for Sale 4 04-19-2015 07:28 PM
Got a quote for my seat - does this seem about right? 19fifty4 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 05-26-2012 01:53 PM
steering problems coltabsh 1987 - 1996 F150 & Larger F-Series Trucks 16 01-19-2011 12:35 PM
Fuel Pump Relay Problems Matt Nalley 1987 - 1996 F150 & Larger F-Series Trucks 2 02-17-2003 06:39 PM
Power Steering Pump Problems Matt 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-13-1999 07:30 AM
Tags
150, 2000, 56, binding, difficult, excursion, f250, ford, issues, lifted, power, problems, steering, streering, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
