Weird turbo noice at start up? "04 6.0L"
Just the last few days on cold starts the motor fires kind of slow then a few seconds later it makes a noise sounds like a bird chirp or a blow-off valve. But the 6.0L don't have blow off valves. I'm assuming it's from the turbo. After the truck runs for a couple seconds longer you can hear the turbo spool up and whistle like normal. It has a 4" cat back with a cat delete and Xcal3 with custom tunes. Any ideas?
I would say more of a bird chirp more like a blue jay !!! I'm pretty positive it's the turbo but hay you never know. I'm located in Medina Ohio. Yeah it got cold again. I've been wanting to get a grill cover for the last couple years to help keep the truck warmer in the winter months. I finally ordered one yesterday from cabelas but they are back ordered.
I had the same noise when I started my truck it was like a 1 second squeak, and then about a month later I lost horse power, I took it to the dealer and they scanned the computer and said it had a under boost DTC, the turbo variable vanes were stuck, and they replaced it with a rebuilt turbo and the squeak was gone.
Well the sounds seems to have gone away. The only thing I can figure is it was the oil. I have always run Rotella dino oil in it. When it was in the shop for head gaskets the changed oil with fords oil they use. I just changed oil and used Rotella synthetic this time. After a few hundred miles the noise has gone away. I've read where the 6.0l has had some problems with dino oil gumming up the injectors and turbo. I did run some hot shot secret in it over 10,000 miles ago but I didn't notice any differance after 5,000 miles. I also had a oil analisis done and it showed everything was good. So I wonder if it's the oil from the ford garage that did it or me switching and then me to synthetic that stopped it?
My truck does this occasionally, I think your probably hearing your turbo vanes sweep closed into the warm up position. Mine was pretty audible, sounded like a door creaking. This was when I first bought it. I don't think the guy I bought it from drove it very much. Now that I drive it daily the noise has pretty much gone away. Except occasionally it will chirp like you describe (maybe once a week). It doesn't seem to be hurting anything so I haven't worried about it. The best way to get rid of it is probably to clean the soot out of the turbo.
Mine just started making what sounds like the same noise. I just posted about it a couple days ago, with not much response. I havent had a chance when its cold to get someone else to start the truck while I listed but Im not going to spend much time on it as Im taking it in this sat for a BAD cold start issue and get the latest flash, I will have them check this too. I just cleaned my trubo less then 10K ago.
Otty
06-03-2017 11:59 AM
beaud82
1999 to 2016 Super Duty
07-29-2009 04:04 PM
