Frame restoration
Frame restoration
I have a frame for a '78 F250 that I would like to make over. I don't have the means to get my hands on a sand blaster or anything like that. What would be my best way to get the rust off as best as possible and what should I paint the frame with for best rust protection?? Also, I would like to replace all the leaf spring mounts, anyone have any ideas where I can purchase new ones, along with cab mounts, shock mounts and most any other mounts at this point??
While the method I took was to take the frame to my nearest powdercoater, and had it blasted and coated, the cheaper options available would be to use wire wheels on your drill or grinder, and start grinding away the rust/grease/crud/etc. Once you get the frame relatively clean, and wipe it down with grease/wax remover, you can use products like POR-15, or Rust Bullet, or any other of a number of products that are supposed to convert the rust to an inert form and provide a strong protective coating. Basically, you'd only be into it for the cost of the wire wheels, the coating materials, and brushes, and time in labor.
LOTS of time and labor. For $450 bucks you could have a 2HP 33gal compresor and soda(convertable to abrasive) blaster! I dont get why people dont just put the money out there for this equipment. Think of all the uses even beyond your truck! Hell rent it out at $30 a day to someone else to offset the cost. Now I know a permenant mount 60gal or larger compressor would be better suited, but I get away with the above set-up just fine!!! Small money for such convieniance IMO.
sandblasting/media blasting is the best way and I have done it in my driveway with a small workshop compressor. Make sure you scrape off all of the grease and big chunks of rust first.
POR15 when you are done and you are golden.
I am in New York, and trying to find a decent cab is not going to happen it seems. And, nope not the rubber mounts, I mean the actual mounts. The only ones that look bad are the cab mounts on my frame. The rest I was just going to replace for the heck of it. I have decide to purchase a small compressor and sand blast the frame. I will start posting pics as soon as I get started. Any body have any ideas about the cab mounts. They are solid but the opening where the bushings sit is pretty well shot. Would rather just replace them if possible.
I feel your pain. My frame mounts for the cab were pretty well toast. The sides were fine, but the centers were thin or non-existent. I torched the hole out to where the metal was still thick by the edge. I then used a die grinder to clean up the slag. After making a cardboard template of each hole, I made patch pieces, welded it up, and ground it back into shape. I went to the cab and carefully measured the mounts so I could transfer that to the newly patched frame mounts. I used a hole saw to remake the factory hole. If that sounds like a pain in the ***, that's because it was. But, the frame is now repaired right, and you'd need to take the cab off to tell it's been repaired. I'm not aware of anyone reproducing the frame mounts for the cab. That would certainly be easier.
Also, I had the frame sandblasted by a pro. Then I had it sprayed with good epoxy primer followed by some black industrial paint. The stuffs made by Dupont and it's called Imron. It's the same stuff they paint semi chassis with. It looks great and it's bombproof.
My personal opinion is to forget about buying the equipment to blast it yourself. The portable sand blasting pots are good for little stuff, but for a frame it would be like trying to water your garden with a squirt gun. And that 33 gallon compressor is going to give you about a minute worth of blasting before you have to wait for it to catch up. Sandblasting requires a ton of air. The pros have gigantic air compressors and they can spray sand like a fire hose. There is no way I could have gotten my frame anywhere near as clean with my portable blast pot. I paid $500 total to have my frame blasted and painted.
Just my .02
-Jared
Just my .02
-Jared
A couple of years ago I restored a K5 Blazer.
I took the frame and running gear to a sandblaster in SLC. It cost $350.00 to have everything done.
This year I bought a 110 lb sandblaster to use with my air compressor at home (5 HP, two-stage, 80 gallon tank). I sandblasted several items and I'll tell you it's not a fun job.
I would rather pay someone else to do a full frame.
Imron is great paint, but it has another spelling: e x p e n s i v e!
