2.5" Leveling Kit + V/C code Install = 4.5" lift!!! - Page 2 - Ford Truck Enthusiasts Forums
Old 01-28-2010, 11:14 PM
RMBC Freeride's Avatar
RMBC Freeride RMBC Freeride is offline
RMBC Freeride has a good reputation on FTE.RMBC Freeride has a good reputation on FTE.
Mileage for one. The yard I used only has low miles stuff (my rear springs). But on the other hand, as mentioned above my front springs were very used and they are fine too... Perhaps I just got lucky on those. I know the F-350 they came off had about 140K on it of hard use. the guy was a metal building contractor and his truck had a massive service body bed unit installed with a welder, etc. Plus he hauled a gooseneck trailer with it to all his jobs...
Old 01-28-2010, 11:29 PM
hhcobra hhcobra is offline
hhcobra is gaining momentum as a positive member of FTE.
Neil, I tried the code for the discount for Summit and it didn't work. Was that only for the Summit kit that you ordered? Thanks!!
Fred
Old 01-28-2010, 11:33 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
I hear ya, Neil. Hit or miss. Thanks for all the info!
Old 01-28-2010, 11:35 PM
housedad's Avatar
housedad housedad is offline
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
I just found out from Summit that they have stopped all promotion codes at this time. (they answered by email. just read it)
Bummer.
Old 02-16-2010, 01:28 AM
2000ca250 2000ca250 is offline
2000ca250 has a good reputation on FTE.2000ca250 has a good reputation on FTE.
just a simple question, but how exactly can you tell the difference between teh different codes of springs? my front end is starting to sag and i'm interested in doing the v-code swap
Old 02-16-2010, 09:48 AM
Quote:
I assume you're talking about the F-250 in your Signature? If so, you probably have V-codes already. Unless you have the plow package in which case you would have X codes.
Either way, look at your door sticker for the spring code & post it here.
Old 06-10-2010, 07:04 PM
Shepherd2 Shepherd2 is offline
Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.Shepherd2 has a good reputation on FTE.
I just came across a set of V/C springs, how much lift would they give without any mods? Is the ride very harsh, arent they rated at 8000lbs? Been searching awhile but not much info on the c code springs.
Old 06-11-2010, 12:08 PM
There should be plenty of info around here about how much lift the V's will give you up front... If you have a diesel, it will be .75" to 1". If you have a V-10, it will be more lift than that.
As for the C's in the rear, I believe they will only lift about the same as the B's. I might be wrong, but I think the C's are similar to the B's except for the overload springs on the C's (which I removed - they don't work on the Excursion). So essentially, IMO, the C's become B's when you remove the overload leaf setup. So expect to get roughly the same amount of lift as B's, which is not much, unless you use the 3.5" tapered F-350 block in conjucntion with the C's (or B's).
Please, anyone correct me if I'm wrong... otherwise, hope that helps!
EDIT: Forgot to add... Mine does ride stiff, mostly due to the leveling kit and the leaves I added to the rear pack. I'd say it rides like a F-450, very solid, a bit harsh for some people. but I like the tight feel and the solidness when I tow. I hate trucks that drive like they're riding on marshmallows!!!
Old 06-11-2010, 01:24 PM
Thanks for the info. It was the C springs I wasnt sure about. Worried about riding it like a tank.
Old 06-12-2010, 10:56 AM
Quote:
I think if you use them alone, without adding leaves like mine, the ride will be similar to the B's. That being said, I don't know what stock B's (or C's)ride like since mine are modified.
Old 06-14-2010, 01:48 AM
02xxx 02xxx is offline
02xxx is starting off with a positive reputation.
Help me out here I just purchased an 02 v10X and have no idea what a V code is that you are talking about for the lift kit could you explain??
Old 06-15-2010, 11:16 AM
A V-code is a OEM Ford front spring from a Diesel F-250 or F-350. By putting them on and Excursion, it lifts the front and provides more clearance between the axle and the bump-stops.
Do a search for "V code" and there should be hours of reading on the subject...
  #28
Old 06-15-2010, 03:51 PM
RMBC I am in Commerce-city CO. I get it, I was into jeeps before so the Diesel is a heavier spring which in turn will provide lift for a V10.
  #29
Old 06-15-2010, 06:44 PM
Quote:
And also , the F-series trucks came with taller springs than the excursions did, regardless of engine. The factory Excursion springs are nearly flat when new (and reverse arched when sagging), to keep the ride-height lower for "soccer moms & parking garages" Also presumably to offer a softer SUV type ride quality... Too bad it smacks the bump stops and makes the ride worse that the truck version...
Heres a spring chart thread for more info: http://www.ford-trucks.com/forums/17...ent-chart.html
ever get down to Pueblo, you can check mine out
  #30
Old 07-26-2010, 10:26 PM
MountainX MountainX is offline
MountainX is starting off with a positive reputation.
Hey RMBC, I'm getting ready to the same swap and lift you did on my 03 Ex PSD and was wondering what u-bolts to go with in the rear with mod B's
2002 Excursion Limited Parting Out Sunline Fan Ford Truck Parts for Sale 373 01-29-2015 10:40 AM
7.3 PSD Swap Project into 2005 V10 Excursion Sunline Fan Excursion - King of SUVs 378 08-21-2014 11:20 AM
Parting out Ford EXCURSION RMBC Freeride Ford Truck Parts for Sale 285 05-28-2014 06:17 PM
Installed '05-'07 Lariat Woodgrain Dash Panel & Navigator wheel in my Excursion RMBC Freeride Excursion - King of SUVs 38 03-13-2014 07:42 PM
2nd Row Seat swap info: Bench/Buckets (will it work?) RMBC Freeride Excursion - King of SUVs 20 04-14-2012 09:03 AM
Tags
25, code, country, excursion, f250, f350, g782, inch, kit, leveling, lift, psd, spring, summit, treardown, tuff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
