Cleveland Heads on a 351M?
From personal experience, both Holley style and Carter style carbs work good on the 351M with an Offenhauser intake, it is easier to tune the Carter type for optimum performance. And if you can find one, the Offenhauser Dual Port 360 manifold works very well with the stock heads on a 351M. Great low end performance with a good top end when you want it.
Ford 351 Cleveland
The 351 Clevelands and 351/400M engines have large, square heads with splayed valves and eight cover bolts. Cleveland heads are marked with a large numeral 2 or 4 in the upper corner of each head, signifying either a two- or four-barrel application. Produced only with two-barrel carbs, 351M/400 engines either have an "M" on each corner or no mark at all. The only way to tell a 351M from a 400 is by measuring the stroke. The 351M stroke is 3.50 inches; the 400M stroke is 4.00 inches.
Johno.h
01-09-2016 02:49 PM
48Basketcase
23
06-04-2007 08:30 PM
84Maztang
06-13-2003 04:58 PM
