fuel mileage
fuel mileage
So maybe im being dramatic but it seems like my truck gets pretty bad gas milage. It's a 96 F150 xl. 4x4 4.9l. It has 3.55 gears and 31x10.5 A/T's. It has 1.5in. spacers in the front and slightly bigger blocks in the rear. I fill the front tank up, usually put about 16 gallons in. The rear tank is empty and i have no load. I drive mostly city type driving. I get about 180 miles untill i fill up, another 16 gallons. That seems pretty bad to me thats like 12mpg? any ideas why it's so bad? thanks
Sounds pretty average to me or even slightly above average with your tires. You could bump your timing and see if there's knock. If you want to stick some cash into it you could always do a tune up and upgrade your ignition then bump your timing even more. Electric fan really help gain some mpg too.
It sounds like most 5.0's can get up to 13.5 degree timing with 97 octane. My 87 5.0 with the ignition upgrade pulled 12 degrees but I also run 32's so this will effect how much timing you can advance.
Also do you fill with 10% ethanol mix? I know I get a good 2 to 3 mpg less when I use ethanol blend.
i hav the same setup, 90 with 4.9 and 31/10:50 tires. theres a formula for the tire difference, anyway im getting 15 mpg. ill see if i can find the formula and post it, because you have to compensate for the tire difference. ofcourse you have to enter your stock tire size then the tires you have now and it gives you the formula to get the proper mileage. http://www.dakota-truck.net/TIRECALC/tirecalc.html
