I just put an intake on my IDI that I think could benefit the gas trucks as well, or even give someone an idea to fab up there own. The kit I got is made by Hypermax, it's a cowl induction kit. You cut a rectangular hole in your firewall above the brake booster and it lets you pull in cool air from the high pressure cowl area. I have noticed a drop in exhaust temperature of 150*, which means cooler air is coming in. Just thought I would share this with you guys since it seems to be working pretty well.
The firewall attachment is a few inches above the bottom of the cowl, so there would need to be a lot of rain. The cowl also has drains and the airbox has a drain as well so I'm not worried about the rain.
The tube diameter is 4", most parts stores around here have a bunch of different sized hose couplers for the ricers, so something could be easily put together. I see no reason why this couldn't work on gas motors. It's just a different kind of cold air kit.
