How to clean the egr valve - Ford Truck Enthusiasts Forums
Old 01-28-2010, 01:15 AM
Rusty924x4 Rusty924x4 is offline
Rusty924x4 is starting off with a positive reputation.
I have a CEL and pulled code for egr valve not working right. I put on a salvage yard sensor and no change. I pulled off the two bolts holding on the top of motor and cleaned up some. Not really dirty. I guess I am asking it I loosen the bolt holding on the egr tube it this is where it will be gumed up and needs to be cleaned. This bolt is really rusty on my truck. What size is this bolt. I don't have the right size wrench for it. I can not buy a new $200 erg valve just now. Thanks for any help guys. This is on a 92 f150 6 cyl 300 ci 4x4 short bed 5-speed regular cab stock two door xl rusty green bench seat roll up windows no air 31" tires 152,000 miles LOL 3.08 gears too!
Old 01-28-2010, 01:46 AM
Mr. Finch Mr. Finch is offline
Mr. Finch is starting off with a positive reputation.
I just used some brake clean and parts cleaner on my. I have a 5.0 and don't come across any of the old inlines at work so I don't know the size of the nut.
Before you put it back on try to blow through it, (you should not be able to). Then try to bloe through it while you have it hooked to a vacuum pump, it should open. If not then it is either still plugged or it is bad.
What exactly did the code say? insuficient flow? Too much Flow?
Old 01-28-2010, 03:31 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
From my experience, usually when that needs to be done its better to just buy a new one. Cleaning it may or may not help. If it does, its likely that the problem will come back later. I would check to make sure that the sensor on the EGR is not the problem.
Old 02-25-2011, 01:32 AM
Slowroll90 Slowroll90 is offline
Slowroll90 is starting off with a positive reputation.
It's easily removed for cleaning
I sprayed it top and bottom with WD-40 and soaked it
then with a racket wrench extension i gently actuated the valve in and out a few times
blew out any particles with air duster, and repeated that about 3 times, the reinstall being careful the gasket didnt disintegrate(which is likely will, these are cheap)
I havnt gotten a CEL since so i think it worked
1995 E150 302 V8 - Can I remove my throttle body leaving EGR Valve attatched? RUSTY_BUT_TRUSTY 1968-2013 Full Size Vans 6 08-04-2015 07:26 PM
351C 4-bolt block-save or scrap? TigerDan 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 10-06-2014 01:01 PM
Dreaded 2.3 8 spark plug change 95 ranger Crewcabber Ranger & B-Series 4 07-06-2014 07:32 PM
Another P401 EGR problem cekingsley 3.8 & 4.2L V6 4 09-28-2013 04:27 PM
My 98 F150 401 codes dilemma finally solved! Passe billyboycurran 1997 - 2003 F150 3 02-05-2011 09:42 PM
Tags
1995, 2004, 302, 50, 92, clean, cleaning, egr, erg, f150, ford, truck, trucks, valve, valvue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
