Fuel Pump Shut Off- needs reset - Ford Truck Enthusiasts Forums
Old 01-27-2010, 05:32 PM
jeffstoner jeffstoner is offline
jeffstoner is starting off with a positive reputation.
i have a 2005 f150. i hit a speed bump, and engine completely shut down, did some research found out about 90% people said it was probably do to this auto shut off switch. i check the manuel, know i am searching in right spot but still cant find it. can anyone help? i dont know what to look for.
Old 01-27-2010, 06:18 PM
Sako 75's Avatar
Sako 75 Sako 75 is offline
Sako 75 is starting off with a positive reputation.
According to my Haynes manual the inertia fuel shutoff switch is located behind the passenger side kick panel, ahead of the fuse and relay box.
Hope this helps. I will look for more info and post if I find anything.
Good luck and let us know if you get it straightened out.
Old 01-27-2010, 06:20 PM
Sako 75's Avatar
The IFS appears to be just in front of the fuse box. The reset button is on the top.
Old 01-27-2010, 06:43 PM
Got it finally. i wasnt looking far enough in front of fuse box. its definitely there... big red button. thanks for the help.
Old 01-27-2010, 08:52 PM
JoSHN JoSHN is offline
JoSHN is starting off with a positive reputation.
Thats one hell of a speed bump to shut the fuel switch off. The last time I had witnessed a fuel switch shut off, was when I watched some idiot in a ranger bomb his truck through a series of whoops and ruts. The last rut was a big one, and he slammed the truck down hard. Thats when it shut off.
Old 01-27-2010, 11:39 PM
grego37 grego37 is offline
grego37 is starting off with a positive reputation.
did it throw any codes?
heater shut off valve bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 20 10-10-2012 06:55 PM
MY 91 7.3 wont shut off thebus1978 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 11-05-2010 12:47 PM
Where is the inertia switch (fuel pump shut off) located on a 2006? helper auto 1999 to 2016 Super Duty 2 06-17-2007 10:58 PM
Interior light delay jasonschwenk Electrical Systems/Wiring 2 11-27-2006 03:07 PM
'92 Ford F250 Fuel Pump Shut Off russell2rx Fuel Injection, Carburetion & Fuel System 1 04-13-2003 07:58 PM
Tags
150, 1994, 2004, 2005, 2008, button, f150, ford, fuel, ifs, pump, reset, shut, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
