Hissing - Air Leak sound on acceleration - Ford Truck Enthusiasts Forums
Old 01-27-2010, 04:51 PM
joejacobi joejacobi is offline
joejacobi is starting off with a positive reputation.
Over the past few weeks I've noticed a hissing sound on acceleration? sounds like an air line leaking coming from the engine, can hear it with windows down and up. However, it doesn't happen all the time?? oddly very speratic? almost seems like there's a little loss of power as well, not really that noticeable though. Checked underneath the hood, didn't see anything wrong - unfortunately it happens only during acceleration when driving.
Old 01-27-2010, 05:13 PM
onelionhunter onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
Weather
Where are you located, cold weather area? What has the temps been lately?
Old 01-27-2010, 05:16 PM
flatbeder's Avatar
flatbeder flatbeder is offline
flatbeder has a very good reputation on FTE.flatbeder has a very good reputation on FTE.flatbeder has a very good reputation on FTE.
I was going to suggest you check all your I/C boots. But you mentioned that you checked everything under the hood. Have you done a aftermarket in-take? If so it could be surge your hearing from the turbo? Hopefully someone comes along thats more intellengent then me who could help you out bud. Good luck!!!
Old 01-27-2010, 05:19 PM
EBPV
I am thinking it is the exhaust back preasure valve he is hearing, why I asked if it is cold there, it makes a serious racket. Might be the tube is rusted through as well.
Old 01-27-2010, 05:20 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Probably a boost leak... Try tightening the boot clamps.
Old 01-29-2010, 08:19 AM
Blacked-Out's Avatar
Blacked-Out Blacked-Out is offline
Blacked-Out is starting off with a positive reputation.
Defiantly thinking EBPV valve. My truck gets like that when its really cold out. Usually stops after a few miles and its warmed up. Does is stop when you hit the throttle hard?
Old 11-09-2011, 12:24 PM
speedworks speedworks is offline
speedworks is starting off with a positive reputation.
Bringing this back from the dead. I have heard this recently in my truck, it is cold out now, and it only happens when it is cold. Once the truck is fully warmed up, I don't hear the hissing sound. If I step on the throttle hard, it also doesn't make the noise. Any suggestions?
Old 11-09-2011, 02:24 PM
ok, I've done some more research and it appears that this is caused by the EBPV. Now the question I have: should it do this while driving (it is a loud noise, and happened after 10 minutes of driving), ie is it normal?
And if it shouldn't happen, should I just disconnect at the valve and not worry about it?
It doesn't seem normal to me, because it is loud when driving (at cruise).
Air Leak Turbo Question brenthottle 6.0L Power Stroke Diesel 4 06-27-2015 11:15 PM
Loud air sound up front Headviking 6.0L Power Stroke Diesel 5 06-18-2015 06:43 PM
Powerloss/Hissing Problem Northstar55 1999 - 2003 7.3L Power Stroke Diesel 5 04-20-2015 09:16 PM
Blow off valve or boost leak problem? Help Old and Busted 1999 - 2003 7.3L Power Stroke Diesel 25 11-19-2008 03:37 PM
Cold weather power loss/hissing Mr Haney 1999 - 2003 7.3L Power Stroke Diesel 4 10-28-2006 01:18 AM
Tags
73, acceleration, air, engine, f250, ford, hissing, hood, leak, makes, noise, sound, sounds, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
