04 F250, 6.0 turbo diesel - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-27-2010, 04:34 PM
jfmaz's Avatar
jfmaz jfmaz is offline
jfmaz is starting off with a positive reputation.
Any comments on the 6.0 Turbo Diesel, how long should it last? I was told the 6.0s in this year are junk? Or is someone trying to make us sell the truck instead of fixing the egr and egr trigger?
Old 01-27-2010, 08:58 PM
Surge08's Avatar
Surge08 Surge08 is offline
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
I have an 2004 F350 with the 6.0 but have the updated engine, and I love my truck. I would Fix it
Old 01-27-2010, 09:11 PM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
I have a 2004 crew, 03 engine. Heads done at 204,000km currently at 340,000km(210000miles). I run about 1500km per week. Don't be afraid of these engines.
Do the maint as required when required. Its a fine engine, just needs to be treated right.
I have owned n IDI, 2 97 7.3, 1 2000 7.3, and this 2004 6.0.
Engine wise my faves were the 97's and the 6.0.
I vote fix it.
Old 01-27-2010, 11:13 PM
PinkyRingz PinkyRingz is offline
PinkyRingz is starting off with a positive reputation.
I am thinking about buying the exact same truck, heard more about headstud issues then anything else. i dont plan on racing it or anything. Bigger tires adn that'd be about it.
I just want a nice reliable stocker diesel for cruising.
Opinions?
Old 01-28-2010, 08:45 AM
rjfetz1 rjfetz1 is offline
rjfetz1 is gaining momentum as a positive member of FTE.rjfetz1 is gaining momentum as a positive member of FTE.
As i have posted before...I had my 06 6.0 for 1 1/2 years...no more diesels...to many problems... and to much $$$$ for everyday maintenance. Get a V10.
Old 01-28-2010, 01:00 PM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
Quote:
There is really no way to answer this question because it depends on things like: was the engine a problem child from the factory, how has the truck been driven, how has the truck been maintained, has there been any reliability mods added, has there been any performance mods, etc. All that being said I have read of properly maintained 6.0L engines that have 300K miles (i.e. the engine should last a long time).
I think most people would agree that the 2005 and later 6.0L engines are better than the 2003 & 2004. However, there are many people with '03 & '04 models that have been very happy with their trucks.
I would spend the dollars on repair if you have had good luck with the truck to date and have maintained it well. The EGR is common issue for these trucks, follows are some links for more info and proper cleaning procedures.
http://www.forddoctorsdts.com/articles/article-05-01.php
http://www.forddoctorsdts.com/articles/article-06-12.php
http://www.forddoctorsdts.com/articles/article-05-15.php<O</O
Old 01-28-2010, 04:31 PM
jfmaz's Avatar
Thanks to all, I am going to try to make them keep the truck. It is a company truck, has has 3 main drivers, two have been conservative, one a younger madman (ah, yes, and there lies the trouble). Truck only has 120,000+ miles on it.
I know they will replace it with a gas truck - so I say KEEP IT!!
Wish me luck with the big guy, J
Old 01-28-2010, 10:17 PM
droffan droffan is offline
droffan is starting off with a positive reputation.
Mileage on the 04' 250
just purchased a nice 250 with a banks exhaust and am getting 16 average. that is with mileage up and down a 6% grade every time i drive into wenatchee. does anyone know what gears came in the 04 and if so by changing gears would i increase the mpg? thanks
Old 01-29-2010, 08:36 AM
Cowboy65's Avatar
Quote:
Look at the axle code on the door jam sticker and match it to the following:
18 3.08, non-limited slip, F-150<O</O
19 3.55, non-limited slip, F-150, F-250<O</O
26 3.73, non-limited slip, F-150, F-250<O</O
27 3.31, non-limited slip, F-150, F-250<O</O
28 3.73, non-limited slip, F-150, F-250<O</O
H9 3.55, limited slip, F-150, F-250<O</O
B6 3.73, limited slip, F-150, F-250<O</O
SCT 3015 Tuner 6.0 Turbo and more Bullitt390 Ford Truck Parts for Sale 0 12-19-2015 03:16 PM
EGR replace vs. EGR delete? kyleec69 6.0L Power Stroke Diesel 15 09-19-2015 06:31 PM
2006 6.0 diesel egr ben158 6.0L Power Stroke Diesel 4 02-24-2015 12:40 PM
compare southern hunter56 1999 to 2016 Super Duty 2 02-04-2011 01:54 PM
Why does my 6.0 Excursion smoke!!!!! ddubbs79 6.0L Power Stroke Diesel 2 02-02-2010 06:13 PM
Tags
04, 4x4, 60, diesel, engine, f250, ford, increase, mpg, reviews, specs, superduty, turbo, view, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
