Installed GDS Fuel Pressure Regulator Spring.....Mileage Down
Old 01-27-2010, 02:10 PM
DSMMH's Avatar
DSMMH
DSMMH is offline
Mileage is down 1.5 to 2.0 MPG since spring install. Normally got 15.5 to 16.0 MPG around town and 20.0 MPG on the road. Now I get 13.5 to 14.0 MPG and have not made a road trip yet. Anyone else install the GDS spring and have the same issue?
DSMMH
Old 01-27-2010, 02:37 PM
1954oldred's Avatar
1954oldred
1954oldred is offline
I just did mine 2 days ago, My mileage has not changed either way according to lieometer.
Old 01-27-2010, 03:41 PM
smokersteve's Avatar
smokersteve
smokersteve is offline
DSMMH
How did you go about doing this?
Did you make sure every thing was clean?
Replace filters??
Old 01-28-2010, 11:30 AM
DSMMH's Avatar
DSMMH
DSMMH is offline
Replace filters??
I removed the fuel supply line and the 4 screws and then pulled the cap off very carefully. I removed the old spring, careful not to loose the brass fitting the spring fits into, inserted the GDS spring and put the cap back on. No leaks.
Everything was clean. I'm **** about cleanliness.
Have about 11,000 miles on current filters so that may be the next thing.
DSMMH
hubler13f
08-08-2010 11:48 AM
DSMMH
02-19-2010 10:03 PM
teppler
02-19-2010 11:08 AM
teppler
01-22-2010 07:23 AM
04redstroker
05-18-2009 12:40 AM
Quick Reply: Installed GDS Fuel Pressure Regulator Spring.....Mileage Down
