tow mirror bulb replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-27-2010, 11:37 AM
in heat's Avatar
in heat in heat is offline
in heat is starting off with a positive reputation.
I have an 08 with tow mirrors and I need to replace the bulb on the passenger side , how do I get the mirror apart? I really don't want to break it?
Old 01-27-2010, 12:13 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
between the glass and the frame on the outside edge you can use a small screwdriver to release the clips that hold the light housing, which will slide forward.
here is a pic with the area circled
Sam
Old 01-27-2010, 03:08 PM
in heat's Avatar
behind the mirror?
Old 01-28-2010, 01:48 PM
sdetweil's Avatar
to the top
Old 11-06-2010, 12:48 AM
woodsters woodsters is offline
woodsters is starting off with a positive reputation.
Would this be the same on a 2010 F250? Do you push on the clips?
Old 11-06-2010, 05:17 AM
scraprat's Avatar
scraprat scraprat is offline
scraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant future
It's not that hard guys, walk away from the computer to your truck. Turn the mirror all the towards the truck and peek in there, use a flash light for better light. Poke and pop it out, change the light and push back in. sdetweils pic is right on.
Old 11-06-2010, 07:33 AM
sdetweil's Avatar
Quote:
yep, still the same.. one clip on the inside holds the whole housing, which slides forward off the mirror
sam
Old 11-06-2010, 09:25 AM
Pappy1911's Avatar
Pappy1911 Pappy1911 is offline
Pappy1911 is starting off with a positive reputation.
Many thanks for your help folks... I'll go out side and have a look. Another problem, all the searching for mirror part numbers only show the standard mirror, not the tow mirror. Any help with the part numbers? My problem is the amber lens is broken out and the local Ford dealer cannot find the tow mirror parts....
Old 11-06-2010, 04:05 PM
Someone on another forum mentioned turning the mirror not only in towards the truck but up as well. Went and did that and was able to see the clip without a flashlight. It's a big metal clip. Popped it out with a small flat head screw driver.
Old 11-06-2010, 04:15 PM
Pappy1911's Avatar
Bingo..I see several places that appear to be clip areas...will try to remove at a later time.. Thanks again all.
Old 11-06-2010, 09:13 PM
sdetweil's Avatar
The clip is about 1.5 inches wide, directly in line with the lens
Sam
Old 11-07-2010, 03:51 AM
Yep...was an easy fix...luckily all that happened with mine was my wife hit something with the mirror and it caused the mirror to fold in. She noticed a day or so later that the light wasn't working on it. When I popped it off yesterday, the bottom bulb had came out of it's socket. Pushed it back in and works like new. Unbelievable how hard it was to try and find information on this. Didn't see info in the owners manual about it either.
Old 10-12-2011, 02:21 PM
TXtinct's Avatar
TXtinct TXtinct is offline
You'll shoot your eye out
TXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputation
Anyone know what type of bulb this takes?
Old 10-12-2011, 02:51 PM
Pappy1911's Avatar
Quote:
They are probably LEDs....
Old 10-12-2011, 03:49 PM
TXtinct's Avatar
I don't think they come from the factory with LEDs. I'm guessing 168 or something like that.
Rear turn signal not working; quick blink. It's not the bulb. Fastfwd 1999 to 2016 Super Duty 6 08-22-2013 10:02 AM
Another towing mirror question remix01 Excursion - King of SUVs 1 02-19-2010 01:26 PM
How to replace parking light bulb in mirror? cshaak 1999 to 2016 Super Duty 6 01-05-2008 11:54 AM
Signal mirror lamp bulb replacement brow603 1997 - 2003 F150 7 09-01-2007 04:14 PM
How do I replace bulb in 2001 Expidition signal mirror. tactsarge Electrical Systems/Wiring 1 05-15-2004 08:38 PM
Tags
2004, 2008, 3399, bulb, duty, explorer, f250, f350, ford, ls, mirror, replace, replacement, super, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
