What would be some symptoms of a bad map sensor? - Ford Truck Enthusiasts Forums
Old 01-26-2010, 09:54 PM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
My truck has been feeling sluggish lately and the cel came on.So I put it on the scanner and it brought up malfunctioning map sensor.So first of all i just went to the junkyard and got a used one but it didn't make a difference and the light came back on.So the truck runs fine at idle,but it just has an occassional misfire out the exhaust.And when I accelerate hard from a stop the truck just feels flat,and no power,it will cruise fine down the road but just sucks the gas and is a gutless wonder right now.So would all this be the cause of a bad or malfunctioning map sensor? Thanks guys.
Old 01-27-2010, 07:00 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
It could be, but also check the vacuum line to the sensor and check the condition of the wiring back to the computer. MAP sensors aren't cheap, so make sure that the sensor is the problem before throwing down the money for a new one.
Old 01-27-2010, 07:10 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
I would check the fuel pressure and also check for a restricted exhaust.
Old 01-27-2010, 07:38 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
What was the error code(s), by number, you got?
Old 01-27-2010, 01:28 PM
97FRD1TN's Avatar
I don't recall a error code with numbers.I'll have to rescan it,but I do know that the exhaust is not restricted and the fuel pressure regulator didn't take a crap.I do know that map sensor's are not cheap,but i would rather it be that then trying to chase crap down.
Old 01-27-2010, 01:45 PM
rla2005's Avatar
Use this link to view what the frequency output of the MAP sensor should be: Ford Fuel Injection Manifold Absolute Pressure Sensor (MAP)
You should be able to use a DVM that can also measure frequency to verify if yours is within range.
Old 09-04-2014, 06:15 PM
Linda Packwood Linda Packwood is offline
Linda Packwood is starting off with a positive reputation.
my ranger is fine when idling but when put in gear it is idling faster,any clues to why it might be doing this will be greatly appreciated
p0500 code??? jakesterrocks Excursion - King of SUVs 14 08-01-2016 12:09 PM
Bad EGR, Fuel injector's, Coil pack? Where to start? abbydane2 Fuel Injection, Carburetion & Fuel System 0 02-25-2016 08:17 PM
Headlight help please tbugher62 1987 - 1996 F150 & Larger F-Series Trucks 6 12-16-2013 07:21 AM
Best affordable hei distributor dirtynorth49 1973 - 1979 F-100 & Larger F-Series Trucks 57 01-20-2012 03:11 AM
ABS light back on 93' EB twisted limb 1978 - 1996 Big Bronco 2 11-29-2007 04:30 PM
Tags
1987, 2002, bad, checking, f150, failure, faulty, ford, location, map, problems, scanner, sensor, signs, symptoms, syptoms, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
