how does your x handle after lifting?
Mine drives great, No complaints.
I went with F-350 V-code springs up front with a Tuff-Country 2.5" Leveling kit. All together it gave me almost 5" of lift! (more than I expected)
In the rear i did f-250 "c-code" springs (without the overloads) and had to add one leaf from my Excursion spring pack, plus the "snubber" from the EX to get it level with the front.
Nevertheless it rides great. I used Rancho rs9000 shocks BTW.
Hope that helps.
On a side note, maybe some of us Colorado EX guys should meet up sometime? I've chatted with a couple other board members from Colo. Springs with 7.3 Excursions... just a thought.
And if I can be any help with your lift, let me know...
Hope that helps.
I would say it handles better than unlifted. I have had many lifted vehicles and all have handled great. just look for a kit with lots of leaves in the spring pack. more thinner leaves are generally softer ride than a few thick ones.. for example the rancho springs on the front of my Ex is a 9 leaf spring pack compared to factory 2 leaf setup... come on down for a ride sometime. Definitely need to do a Colorado Ex get together...
Sorry to interrupt the Colorado love fest...
My lift took place in stages, first the five inch all spring lift with stock wheel and tires. The ride was way better than stock, especially being up off the front snubbers. Then I added some slightly taller tires (33") with the 18" wheels I bought. I ran that combo only until I could pick out the 35s that I wanted. The ride was still better than stock. With the addition of the 35s (and new gears and LSD) it now does everything I want, but the ride is now a little more harsh. I still love it though.
So yes, you can expect changes, but they don't have to be bad.
here's the thing. I needed new tires a few months ago and bought some 20" rims with 305s on them off of CL. I had them put on but did not get an alignment...wanders all over the place.
My wife drives my Ex on Fridays for school carpool and has told me that I have to get it fixed.
With the 4" lift and 35s (plus alignment when they are on) needs to be a more controlled ride or I am in trouble!
Looking at either a Pro Comp or Super Lift.
Thanks for the input sofar...
and YES, we should set up a CO GTG sometime this summer!
Todd
Todd
I agree with DJ & "Mr Idaho ", it is better than stock as long as your lift replaces the springs. A shackle lift with EX stock springs would make it worse, I'm sure.
Sounds like you need to address some or all of the EX wandering issues. A lift that replaces the springs will take care of part of it... then there's the steering box, ball joints, alignment, etc... Lots of threads out there about wandering
Todd
Todd
if your ball joints or tie rod ends were bad then a good repair shop doing the alignment should have caught it and told you about it
I'm running a 6" procomp lift on 35" BFG KM2's. Single shocks on all four corners and I like it. The factory suspension sat about 1" from the front bump stops so it would bottom out alot. The ride is stiffer but I wouldn't call it harsh. Although the same lift on the F250 rides like a lumber wagon. I think the excursion rides better due to the extra weight it carries.
you can also look into skyjacker 4" spring packs. they sell a 4" kit for an average of $15-$1700 bucks, but if you buy the springs in pairs they are $500 per pair +/-, and then all you need is a u-bolt kit, and a trac-bar bracket and you'll save some coin!
you might even be able to re use the old u-bolts. and just get the trac bar bracket separate and you'll be good to go.
