98 ford expediton ajar and interior lights stay on
i have a 98 ford expedition 4x4 and my door ajar light stays on and so do my interior lights but they turn off when i get to 15 mph but door ajar light is still on and when i open the passenger door no lights turn on has this happened to anyone?
Sounds like one of the sensors for the door or rear hatch is stuck and wont turn off the sensor because it thinks the door/hatch is still open even though it is still closed. Check all the sensors and see if any of them change. Also check for dirty contacts that would also cause this problem. My guess would be on the rear hatch or the rear window.
interior lights
So with my 1998 expedition 4x4 my interior lights would not shut off. And I thought maybe it would just be best to pull the fuse but I didn't know which one to pull. Therefore I am driving home in the dark with my interior lights on. And I start to mess with the dim lights switch just to see if it would shut off and it does! So just mess with the dim lights switch to turn them off. I know it can be a struggle. It was like that for weeks with mine on
Quick fix!
After almost two years, I searched through this forum and found out that the solution to my waking-up-in-the-middle-of-the-night for the alarm going off due to the doors not locking up on my '99 Expedition was just sitting at my garage at all times. Spraying WD-40 on my door latches did the trick and the doors lock now immediately, ajar light goes off right away and interior dome lights shut off right after closing the doors! Thank you guys for such a quick and easy solution!
Donna Pless
1983 - 2012 Ranger & B-Series
01-20-2018 10:25 PM
