Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-26-2010, 07:47 AM
ttttmaxx ttttmaxx is offline
Garage is empty, add now
ttttmaxx is starting off with a positive reputation.
Anti gel
Good morning gents, this forum has always been a great source of information in the past so thought I would try again. I have been running B100 and now that cold is getting serious what is the best anti gel additive. I would like to continue using B100 but guess if an additive is more expensive than running B80 I might just blend. Thanks for your opinions in advance. And if you guys have a preferred anti gel for B100 where do you purchase it?. Im a small time garage bio producer. Make 5 gallon batches at a time. Thanks
  #2 (permalink)
Old 01-26-2010, 08:16 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
I've been adding Diesel Kleen when it's around zero, otherwise running 30% bio. 30% bio runs fine, just a little harder starting...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 01-26-2010, 08:35 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
I've tried every anti-gel on the market, including those made just for biodiesel. Not one has been as good as blending. I just switched from B-50 to B-80 since it's starting to get warmer. Blending has worked good for me for almost 6 years and untill someone comes up with something that works I'll keep on blending.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 01-26-2010, 01:41 PM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
I always use a blend with d#2. When the temps dipped down to the low 20's I mixed down to B30 just to be safe. I see low 30's in the mornings and I blend down to B80 with no problems. Where I get my bio from uses a special process that brings the gel temp's down to 30 deg. So mixing down to B80 gives me a good 10 deg margin. There is another place I get bio from that adds 5% kero which brings the gel temp's down to 25 deg. I add 10% d#2 to blend down to B85 just to be safe. This has always worked for me with no problems. I have never seen a product that actually works better than dino diesel to bring down the gel temp's of the fuel.
http://www.nrel.gov/vehiclesandfuels/pdfs/43672.pdf
__________________
2005 F350 6.0 lariat supercab 4x4 long bed zf6 speed and a real work horse--Burning B100 on nice days and B50 when there is a chill in the air
Mod's-BD exhaust brake-Dura flaps-Piaa back up lights-C-Betr mirrors
-Midwest short throw shifter-Splitz lift-Wilson cell antenna & Amp--Isspro ev gauges-fuel-pyro-ebp
1999 EB expedition (Wife's)
  #5 (permalink)
Old 01-27-2010, 12:30 AM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
Same here on cutting with pump #2. When it got into the teens here last December, I went to B50. My soy based bio begins to gel at the mid 20's. I've been doubling up my glycerol pre treatment lately and it seems to help in lowering my gel points. Last year, doing one pre treatment on my oil yielded bio which began gelling in the upper 20's.
I haven't yet heard of any successful bio additives for lowering gel points. My guess is that there are so many different feedstocks and processing methods that it would be difficult to develop one product which would work on all biodiesel.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #6 (permalink)
Old 01-29-2010, 04:49 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Quote:
Hard to believe but I actually had to cut my bio to B-80 due to the night time temps in the high 20s. That's in sunny Florida folks. Hope we don't see that again. We are "wimps".
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #7 (permalink)
Old 04-05-2011, 08:49 PM
Jeffrey S Brooks Jeffrey S Brooks is offline
Jeffrey S Brooks is starting off with a positive reputation.
It is common practice in the UK to add about 5% gasoline to biodiesel to keep it from gelling when the temps drop to 32F (0c). Below that it might take a bit more gasoline up to about 20% depending upon the night time low.
Tags
04, 2005, 60, anti, antigelling, b100, b80, bioadditive, brew, diesel, f250, ford, gel, home, lariat, makes, motor, reviews, running, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
