I would run a 35" tire, something like a 285/75/18 or a 35x11.5x18 if you can find that. I don't like 12.5" wide, but that's just me (I like narrower). I'll likely go with a 255/80/17 on my truck (33.5x10.5x17).
You should have the TMPS which means you need to run around 65psi or the light on the dash will be on all the time. You will need to find a load range E tire. You should be able to find a few 295's out there. I believe Nitto has some check here https://www.ford-trucks.com/forums/9...ppler-m-t.html
