Tying down a Truck Camper?!
Am buying an '88 Play-Mor 9' truck camper. Towing in my '01 F-350 7.3L.
I estimate the weight to be 2500 - 3000 pounds. I will be driving fairly good Nat'l Forrest roads but will occasionally get into some rough stuff ( I know me).
How safe will tying it down with turnbuckles at the existing corner tie downs in the pickup bed be? I won't have a lot of money invested in the camper, and don't really want to spend another $300.00 on a system like the HapiJak.
Suggestions.............?
When we had PU campers I made a frame mount for the front and tied the back to the bumper. The front one was made with square tubing attached to the frame and the back was just a piece of angle iron attached to the bumper, I used chain and turn buckles from the mounts to the camper. With the box mount that's in the box of a SD I'm sure the box mount would work for the rear chains.
Denny
Denny
I've never had problems on the pickup end, it's always been on the camper. Older slide in's have seen a lot of weather and many times not much attention paid to the tie down hooks. The wood gets old, weathered, starts to de-laminate, hooks get loose, corner jacks start to pull off.
Then you get creative with aluminum angle and channel.
This is what I have used since I bought my camper in 2005. I picked my setup used on eBay and saved quite a bit of money on mine. It is the best and safest setup in my opinion.
Torklift Tie Downs
Torklift Tie Downs
There is a forum similar to FTE that is dedicated to truck campers; it is a part of the NATCOA site (North American Truck Camper Owners Association).
NATCOA FORUM
You will find a wealth of information there. My personal advice is ABSOLUTELY POSITIVELY DO NOT USE the pickup inside bed tiedowns. They are simply small bolts through sheet metal. I have an '08 450 and almost tore one of the forward tiedowns right out of the bed tieing some boxes down. I would only use the Torklift products, they are far superior to the Happijac system. A 3000 pound camper bouncing on a rutted National Forest road that is not properly tied down will do more damage to the camper and truck than the Torklifts would have cost.
NATCOA FORUM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
10-18-2016 06:34 PM
Torklift Sheryl
02-25-2016 12:44 PM
truckfella
10-06-2015 02:23 PM
Torklift Sheryl
04-14-2015 10:38 AM
